8th Gen 2006 - 2011.
Audio Control Problem
Old Feb 19, 2009
dfnail's Avatar
dfnail is an unknown quantity at this point
I have the 06 Civic Hybrid and have a problem with the audio control. The Nav system works fine with proper display on the screen. However, the audio menu does not display even though the radio and CD player work. The scan button also does not function as well as the pre-set buttons at the bottom of the display. The power/volume control **** works fine. Also, the steering wheel control buttons function properly. The unit is out of warranty because of milage and American Honda has refused any goodwill. The dealer has said that all he can do is replace the unit at a cost of $1000. Hopefully someone can suggest how I can get this corrected without such a cost hit. (I am a new member and first time Honda owner)
Dan
Old Feb 20, 2009
rocksinger45's Avatar
rocksinger45 is an unknown quantity at this point
Re: Audio Control Problem
One thing you might try is to so call reboot the unit by disconnecting the battery and reenter the radios code #, if you don't have the code # you can most likely get it from the dealer where you bought your car. Now I'm not sure that this will work but this is a very cheap way to start..... what I would do.
Old Feb 20, 2009
dfnail's Avatar
Thanks. I do have the codes and this is an easy thing to do. This is the anti-theft protection. I am reluctant to do this because the radio is now working. I can at least listen to the pre-programed stations. However, there is no way to input the codes with the display malfunction as it is now. And if the screen does not come up after disconnecting the battery I have lost what radio I do have. Any thoughts on that?
Old Feb 22, 2009
My thinking is that what you have will return because those functions are already working properly, the radio in your Honda is manufacture by Alpine for your FYI. Let me know how it turns out.
Old Feb 23, 2009
dfnail's Avatar
I am trying to get up the nerve to try it. My hesitation is because of the way the anti-theft works. If the radio loses power, it is disabled. So if I disconnect the battery and the radio is disabled and the display is the same as it is now, I won't be able to input the codes, just as I can't input them now. At least right now the radio and CD plays, I just can't select any new stations or adjust the sound quality. Also, the clock doesn't work. Do you understand my dilemma? If losing power caused the problem, then the radio should not be working at all. Does this make sense to you?
Old Feb 23, 2009
is there a reset button on the unit?
Old Feb 23, 2009
dfnail's Avatar
No, not that I know of. There is no mention of one in the owner's manuals. The only reset that is mentioned is the anti-theft codes which I am unable to enter because of the display problem.
Old Feb 23, 2009
I do I understand your problem and I understand your apprehension, if this was me I would do what I said before and reboot the unit or call Honda's main office in Torrance California or my local dealer and ask them for some information on what to do.
Old Feb 23, 2009
dfnail's Avatar
All Honda will say is replace the unit at a cost of $1000 to me. The car is under the time warranty limit but over the milage limit (What has milage got to do with the failure of electronics?). Anyway, I have found an electronics guy who said he will remove the unit and diagnose the problem for $35 and give me an estimate of what it will take to fix it. I guess that is my best bet at this juncture.
Old Feb 24, 2009
Don't know if you know this, but you can contest a warranty problem at Honda's corporate offices, a friend of mine had a paint problem that was solved that way.
Old Feb 24, 2009
dfnail's Avatar
I did take my case to American Honda's Corporate office. The problem is that technically I am out of warranty because of milage. I made a very good case to them about how the failure of electronic equipment is not related to milage but to defects and age. I reminded them of how they even cover their car start batteries based on time without regard to milage. Even if they agreed with me, unless they wanted to offer goodwill coverage, I am out of luck because they clearly state in their warranty a milage limit. I am 5 months under their time warranty which I thought would sway them. It didn't. I am very disappointed to say the least.
Old Feb 24, 2009
I've personally gone after Sharp, Sony & Canon with warranty problems and even after having them say no I bugged the **** out of them everyday and asked "who is your boss" going up the chain of command saying "I want to talk to him" and if that didn't work I told them that I think the courts need to decide this issue and who do I need to take to Small Claims Court and after that if I got no results I sent a USPS Certified Return Receipt letter to them stating my intentions to take them to court and telling them why I think there being unfair with me, by that time and in all cases I got results. If your willing to lay down and play dead they WON...but if you stick to your guns there's a good chance you'll win.
Believe me these people (Honda) don't want to be caught in a court of law (It'll cost them more money to send someone to court than to settle), if they lose there is a test case that someday some collage student could use in a class action case against them.
OK, now my friend had a older Honda Accord that had paint that was flaking on the hood, top & trunk of his car that was at least 3 years out of warranty and he got results by following just what I have written here for you.
P.S. If you do proceed make sure you get names (ask for name & job title) dates & times of everyone you speak to.
P.S.S. Make sure they give you a case #
Old Feb 24, 2009
dfnail's Avatar
My main argument is that a top end electronic component should not fail in less than three years (2 yrs. 7 mos.) regardless of the miles. I have two things against me. The warranty states in clear terms that it is not covered past 36K miles, and, I am the second owner. Honda made a big deal out of that when I asked them to cover it. I do have a case # and the name of the corporate guy who said no as well as the dealer service people who were supportive. The procedure required to dispute the decision is to file an arbitration case with the BBB. So, I could do that. I have done things like this before--sometimes successful, sometimes not. I'm not sure I could prevail in this case, but I am tempted to try it. I would like the opinion of those who are following this thread as whether I should or not. Thanks.
Old Feb 24, 2009
I think you should use the Small Claims Court as I said for your remedy, take it out of there hands. Remember what the great american poet Bob Dylan once said "When you ate got nothing you've got nothing to lose".
BTW, did you ask Honda where it said in the warranty that it was non transferable that in it's self sounds like B.S. to me.
Old Aug 13, 2010
dfnail's Avatar
Just a final follow-up. The independent electronics guy said that it looked like someone spilled something and caused the problem. He sent it back to Alpine. Cost me $300. Everything works fine and this was a better solution than going through Honda.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Optimus34
May 25, 2015 11:52 PM
cukaracha
May 16, 2015 02:11 PM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
