8th Gen 2006 - 2011.
2006-2007 Recall: Wheels may fall off (no joke)
Old Sep 14, 2007
RogerB's Avatar
RogerB is an unknown quantity at this point
Exclamation 2006-2007 Recall: Wheels may fall off (no joke)
Honda is recalling 180,000 Civics made in their Alliston, Ontario plant.
Apparently water and salt can corrode the wheel bearings which can potentially lead to the wheel falling off.
More info here : http://ca.news.yahoo.com/s/capress/us_auto_recalls
Old Sep 14, 2007
rick93684's Avatar
rick93684 is an unknown quantity at this point
Re: 2006-2007 Recall: Wheels may fall off (no joke)
so how do i found if my car neads to be fixed i have a 2007 honda civic
Old Sep 14, 2007
kemlyn's Avatar
kemlyn is an unknown quantity at this point
All:
Have a 2005 civic with 39k miles, started humming when driving. Went to dealer needed front wheel bearing ??? !! 3 k over 36k warranty, $300 fix !! What a screw job. Owned a lot of cars but never replaced a wheel bearing that was listed as sealed this soon in 30 years of driving. My civic was built in Aug 05 wonder if I got the 2006 bearing problem on my late 2005 car ? PS I also had my civics fuel door break,, I have a 1991 Legend with 190k , never replaced a bearing or a fuel door cable in 16 years and I'm the original owner,, my civic is Canadian JUNK.
Old Sep 16, 2007
KenB's Avatar
KenB is an unknown quantity at this point
Originally Posted by kemlyn
All:
Thanks for sharing. If the TSB doesn't include your year, odds are it isn't affected.
Back on topic -- my Honda Owner's Page isn't listing the recall yet but I have a call in to the dealer to find out when the process will begin. I'm betting they don't know yet, but the news story is going to make the owner's hit 'em hard and fast.
Old Sep 16, 2007
RogerB's Avatar
Maybe I'm wrong but the sticker on the inside of the door might list where your car was made.
Or you could always print off the article and bring it to your nearest dealer. They would tell you if your car is affected. Besides, they do the work and Honda will reimburse the dealer for their time to fix it.
Old Sep 16, 2007
CraigW's Avatar
Here is some more info on the recall --> http://www.automotiveforums.com/vbul...d.php?t=751477
My 05 has also been noisy, The front bearings are different, I have not crossed over the rear bearings though.
Old Sep 16, 2007
they will send something in the mail if you are affected.
Old Sep 17, 2007
works4us's Avatar
works4us is an unknown quantity at this point
Plug your VIN number into the following decoder and it will tell you all you want to know about where your car was made.
http://www.pronto-net.com/vin_app/vin.php
Also: I am reading that the recall is only going to replace a seal on the ABS brake sensor that COULD allow water/salt into the bearing causing damage. Bearing damage is not a quiet thing and people would have to live with a lot of noise before I would think a wheel would actually fall off!
Old Sep 17, 2007
exturbo6's Avatar
sometimes they dont...thou.
Old Sep 17, 2007
Luey's Avatar
Luey is an unknown quantity at this point
All the recall VIN series' start with "2" - which means Canadian made (the Alliston Plants, since that's the only place civics are made in Canada). If your VIN does not begin with a "2", then it's not affects (VIN's beginning with "1" are US made).
http://nhthqnwws111.odi.nhtsa.dot.go...7V399-1316.pdf
Old Jan 12, 2008
///Bruce's Avatar
///Bruce is an unknown quantity at this point
Gearbox, that's true. And, thanks. But can't one also pick up a phone, or better still, go to a dealer and ask an SA or SM to check to see if there are any open issues on your vehicle.
I just bought my kid an 07 Si coupe and asked my SA for a complete printout of all work ever done to the car. I was amazed of the list of recall work performed. He also gave me another list of all Honda parts ever installed on my car as well. It also was long.
A few items I remember was an ABS recall, a noise from the rear resulting the replacement of both rear rotors and all rear pads, the front rotors had been turned and a rear(?) boot was replaced because it had a hole in it, there were a few other items of no consequence.
But one thing of interest: the SA told me there had been a lot of issues with third gear and should it happen to bring it in since it was a 'simple' fluid change. When I mentioned this to my kid, he said it had actually happened a few times. So, she goes in the shop next week....
Old Feb 4, 2008
lefty976's Avatar
lefty976 is an unknown quantity at this point
does anyone know which model ie lx, ex this recall affects???
Old Feb 7, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
wow......your wheels will not fall off.....Honda made an incorrect seal around the rear wheel speed sensor. If over a VERY VERY extended period of time it will cause damage from being exposed to salt & junk from roads. I have seen some pretty bad wheel bearings but never a wheel coming off.
I have probably looked at 5,000 new civics & none of them are affected. You bring it in, look at the seal, if it's torn you replace. Thats it!
This is how people blow things out of proportion......Gotta love the car business, alot of misinformed people out there! Affects EX,LX, & DX...Si's are not affected
oh and to comment on the gentleman before....Si's rarely have shifting or 3rd gear problems...mostly I see it as a result of incorrect driving. Also, the rear rotors were probably be replaced because they were warped from doing high speed stops.....honda will warranty most warpage...not hondas fault......just clearing some things up.....
Old Nov 5, 2011
macc2400's Avatar
macc2400 is an unknown quantity at this point
I have 43k on my '06 civic and would like to change the rear rotors and pads. does anyone have any suggestions on what I should use ? I was thinking Raysbestos rotors and any good quality ceramic pad.
Old Nov 5, 2011
oem stuff is usually better than anything you can get at the store.
Old Nov 6, 2011
good god... a thread from 2007 being revived for an unrelated subject...
necromancer in sight! the living dead thread is back!
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
rainman15
Sep 6, 2015 11:10 AM
