Apexi S-AFC
Old Jun 12, 2003
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Apexi S-AFC
today got my S-AFC install and tune, not on a dyno. Anyway I like how the way it is tune. Just got a few question. When I disconnect the battier on the car, does the setting screw up (I mean go back to factory setting)? How do I keep track of what is the setting are like? Plz help because I don't want to keep going back to ask them to set it for me.
Old Jun 12, 2003
reytito's Avatar
hey sorry i can't answer your question..i got one for you instead. can you describe the differences in you felt after installation and tuning? try to be specific...thanks man.
Old Jun 12, 2003
jasonerice's Avatar
jasonerice is an unknown quantity at this point
I to have a S-AFC and if you disconnect the bat. Terminal it will more than likly reset to factory setting because no internal memory. It just has the 12V power and works like you car stereo if you disconnect the batery on your stereo it resets so same priciple. Also it is relativly easy to figure out how to set up and use I don't have mine dyno either but I have 15%throttle @ -3% and @65% throttle I got +3% it works for me and no problems!! I am waiting for more mods to do a dyno but I can tell the difference with it installed.
Old Jun 12, 2003
AFlyer's Avatar
AFlyer is an unknown quantity at this point
nope, try again jasonerice. i have the S-AFC, and i have disconnected the battery numerous times, most recently to install my adjustable cam gear. disconnecting the battery does not reset the settings in the S-AFC, so don't worry about it.
also, you will get the best power gains if you set your settings to be LEANER. this is the chemistry of internal combustion. right now i have mine set at -3% for high throttle, and i don't want to go leaner than that till i get it dyno tuned. the only reason you would run richer is if you were running a nitrous or forced induction system and your fuel mix is TOO lean, as told by the air/fuel ratio gauge that you of course have.
enjoy that.
cukaracha
Aug 27, 2015 02:02 AM
Theshwartz35
Jul 17, 2015 11:13 PM
supraman
Jun 2, 2002 05:59 PM
Mrciviclova
May 10, 2002 09:41 PM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:15 PM
