HELP!!! REMOVING BROKEN BOLT
Old May 29, 2003
SPK2RA's Avatar
SPK2RA is an unknown quantity at this point
Angry HELP!!! REMOVING BROKEN BOLT
Well I was fixing my amp wires so I can start on putting in my system in trunk. I was piecing back together the rear deck and broke the bolt that holds the rotating latch (metal thing that connects both seat backs). I tried one of those easy-out extractors, but no luck, the threads seem to be too interlocked/stripped.
What do you guys suggest I should do? Should I drill out the bolt and then try re-threading it? Should I take it my mechanic and see if they can use a heat gun or weld a new head on the bolt? Any ideas guys????
Old May 30, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If you have a dremel, go out and buy a tungsten burr. I forget the bit number, but its a 1/2 inch skinny cone with a round nose. Run it into the end of the bolt so you get a dimple deep enough to get the easy out into and try the easy out again. The Dremel will rough it up more than a drill so you'll have a better chance of getting the extractor to bite. Still no luck, drill it out, re-tap the hole and get a new bolt.
Old May 30, 2003
SPK2RA's Avatar
Thanks Man, I'll have to try that. I'm gonna see if my friend has a dremel I can borrow.
Old May 30, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
do you have the easy out that Sears advertises that only grabs the head of the bolt, or do you have the kind that you drill into the bolt.
If you haven't tried the kind that you drill into the bolt, they work really well, At Home Depot thier like $3-4 and come in all different sizes, Thier next to the drill bits in the tool coral.
Old May 30, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
yeah try the bolt extracter that drills into the bolt first, if that doesn't work id take it to a shop, they'll be able to get it out a lot easier than you can,........im just saying that way nothing gets *f'd* up
Old May 30, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
last time this happen to me, i took a really thin drill bit. and drilled into the center of the bolt. took a screw driver with pointy tip and hammered it into the hold. and just simply unscrewed it.
Old Jul 1, 2003
deeznuts's Avatar
deeznuts is an unknown quantity at this point
i did the same thing when i was cleaning up my amp wires... i broke both of the bolts off.. i took the seat into honda and the tech drilled the bolts out and re-tapped for free! but since then i bought a tap. i would re tap them to a bigger bolt. i used 10mm instead of 8
Old Jul 4, 2003
DMX's Avatar
DMX
DMX is an unknown quantity at this point
why is this so common??... i did the exact same thing today...
tried to drill it out but that didnt work... so i said F it and just drilled it in! its pretty deep so no i can just put in another bolt.
Old Jul 4, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Now, now lets not think too hard on this one. Brawn over brains. Sucks when you are lazy(its gets all of us). Now which way was harder? Doing it the right way the first time or using a shortcut?
Old Jul 4, 2003
DMX's Avatar
DMX
what the hell are u smokin???? what was the short cut that i used??? stop tryin to flame and keep ur dumbass mouth shut!
manfredww1
Jul 14, 2015 10:24 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
ballmich
Jul 9, 2015 11:59 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
