help quick..reverse indiglo gauges???
ok guys i installed my gauges last night and they worked just fine, well this morning i go to get in the car and hit the unlock button on the remote and it took a little bit longer for the gauges to flash than the other lights, (which i assume is normal b/c you have to get power to the gauges) well when they flashed both worked, but after that only the ones on the left worked, its not a big deal taking them back out and looking but i was wondering if anyone else might have had this happen to them, just so it takes less time.........
p.s. i did search
O.K. I found my problem, first i thought it was the wiring so i checked that out and thats not the problem....the problem is on the back of the gauge where the wire is soldered on...there is a small line where every time i hook the wires on that crack burns...you can see it and smell it buring, my question is how do i fix this????? can i put a bead of solder over the crack to reconnect it or what????????????
p.s. i did search
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
