Vic made 6 beeps when turned on?
Old Apr 16, 2003
cdmx's Avatar
What does this mean? earlier in the afternoon after turning on the car it would beep 6 times...what does this mean....what problem is the ecu trying to tell me..anyone know?
btw it doesn't beep anymore
Old Apr 16, 2003
4bangin's Avatar
ummm, was your door opened or something? was it like the beeping that it makes when your keys are in the ignition and your doors are open or was it like an electronic beep noise?
elaborate on the "beep" a bit for us.
Old Apr 16, 2003
cdmx's Avatar
well im guessing it was the beep that tells you if something is wrong...The ecu tells you....I just wanted to know if anyone knew what "6" beeps meant...It sounds like when you put the keys in the ignition, but it kept going after the car was on.
Old Apr 17, 2003
born2xLr8's Avatar
I think there are extra beeps when you start the car and your seatbelt is not on...
Old Apr 17, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
it is a code you are correct about that, but your best bet is to actually call honda and ask them, but if there no help then ill check when i go into work today and post later...........
Old Apr 17, 2003
white2K2EX's Avatar
I sure wish my car was newer
I know that when you turn the key to the second slot (to work windows but not turn the car on) it'll make six beeps and turn off. I don't know what else to tell you.
Youngciviboy
Jun 10, 2015 03:49 AM
chuffsy
May 15, 2015 12:50 PM
GH04si
Apr 15, 2015 08:13 PM
05civic
Dec 23, 2001 08:34 PM
