Headlight sealing
Headlight sealing
i was looking for the best way to seal a set of headlights. They are the gunmetal housing from tornactive. I want it to look good and seal well. I hear that i have to open them up and reseal them and some say just put silicon on the top. What do i need to do?
i sealed the projectors i have on right now! its not so hard, just kinda tie consuming
just get the silicon you want to use put some on and have a dish of water there to dip your finger in then, withyour finger wet just run it along where you put the sealent and smash it down basicly
anything from liquid nails to clear bathroom caulk will work. but use somthing in a hand tube not a caulking gun either its a pain in the *** trying to squeeze the long tube and aim.
i'd just put silicon on it....but u might wanna make sure its sealed...just ur finger if u need...just wash them off asap. if they fog again just redo it...i'm sure at some point u'll be
just use glass clear silicone...... put enough on...... than the secret to tight seal is to go over
the cracks with extra silicone..... and let it dry.... make sure the headlight holds tight while drying
yea just lay some silicone, super glue, or any kind of good bong into the groove of the headlight and just mash those things together, give them some time to dry too and there ya go
Originally posted by sg2kca
tape up all the holes real good then put it in the freezer for a couple minutes maybe
Sep 27, 2015 11:33 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
