I weighed the Teins vs the stock
Old Mar 4, 2003
artychris's Avatar
artychris is an unknown quantity at this point
STOCK
Front: 20lbs (each)
Rear: 7lbs (each)
TEINS
Front: 17lbs (each)
Rear: 8lbs (each)
So how's a 3lb savings up front gonna help out on the track?
Old Mar 4, 2003
KeNsHiN's Avatar
LEVA
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 4, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: artychris
STOCK
Front: 20lbs
Rear: 7lbs
TEINS
Front: 17lbs
Rear: 8lbs
What the weight difference means, I don't know. The Teins do feel good on the street.[hr]
what are your settings?
Old Mar 4, 2003
KeNsHiN's Avatar
LEVA
how much did you pay?
Old Mar 4, 2003
artychris's Avatar
I have em pretty much slammed with 1 pinky finger gap with the rear a 1/2 higher.
I have the damper on the stiffest setting.
I'll adjust the damper after I break them in for a couple days. It's only been 2 days since I've had em on.
Old Mar 4, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
With that big of a drop, hows the ride? No BS either just because you have them. if they are rough.. please tell [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] As compared to stock how is the ride. Thanks a bunch
~nick~
Old Mar 4, 2003
artychris's Avatar
it feels good. No BS. I can notice the bumps that I would normally ignore because it magnifies it.
I paid 1150 for the set shipped.
Old Mar 4, 2003
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Any of the typical coilover noises we all seem to have?
By the way, I got your voicemail regarding body shops but I cannot tell you (due to short-term memory loss) who paints kits around the local area.
Sorry bud.
Get some pics up though ASAP!
Terry
Old Mar 4, 2003
3rdcivic's Avatar
By the way, I can save you some more weight if you want some 18's. I'm selling my 14.5lb centerline wheels (1 piece rotary forged) w/ tires for approximately $1500 OBO.
Old Mar 4, 2003
artychris's Avatar
I got the 16x7 Rota Slipstreams which should be on my car next week. I would have installed them at the same time, but due to modacar sending me the wrong tire sizes, I have sent them back for refitting.
I am hearing a little bit of the squeeks at very low (5mph) corners, but other than that, these are like stiffer stock springs... and Corollas seem tall on the freeway!
Old Mar 5, 2003
Grey's Avatar
DIY King
Quote
and Corollas seem tall on the freeway![hr]
Haha, that's great.
Anyway, to answer your question... Less weight up front (6 pounds total) and more weight in back (2 pounds total) is going to do very little to help make the car's handling neutral in the corners, but it'll help nonetheless. Our cars have a 60/40 front/rear weight distribution, so the closer you can get that to 50/50 the better your handling will be in the corners. Not true for drag racing though. With drag racing you want as much weight as possible up front since we have a FWD car.
Anyway, to get more technical with the neutral thing... You can do other things to make your car neutral in the corners. Any stock Civic has some understeer, so a stiffer front sway bar would help for example. A wider wheelbase in the front would help as well. Wider tires up front would also help. All of these would help to keep the front planted during a turn thereby getting rid of the understeer. You need to balance this out though 'cause a 60/40 weight distribution isn't that far off from 50/50.
Misfit2613
Jul 30, 2015 09:49 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
EM_WON
Jul 22, 2015 06:49 PM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
