idle
Old Feb 25, 2003
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
idle
When my car is warm it idle to 100-200 rpm. Is it surpose to idle that low. But nothing is wrong. The car don't shake or nothing.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: jrock2324
When my car is warm it idle to 100-200 rpm. Is it surpose to idle that low. But nothing is wrong. The car don't shake or nothing.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
What the hell? No way.... the lowest i can idle is 500rpm. Did you install indiglows? Maybe they are not perfectly lined up with the stock ones.
Old Feb 25, 2003
civicvtec1ps's Avatar
Search and Learn
mines around 700rpm
Old Feb 25, 2003
jrock2324's Avatar
I do have some gauges put in. But when I put them in I let the car warm up and the idle was at 600rpm. But when I put my ingen CAI in the car start idleing at 100-200rpm when it got warm.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 25, 2003
nightcivic's Avatar
nightcivic is an unknown quantity at this point
Highly not possible but my guess is to check the seal between the throttle body and the aftermarket intake you put in. Im no expert though.....
Old Feb 26, 2003
JohnnyLee's Avatar
7thgen guh chee
When my car is warm it seems to be around like 600rpm. When I first start it in the morning well 1500 rpm sound normal!
Old Feb 26, 2003
TeLLy's Avatar
Yes, it's an Acura EL
On startup I idle at 1500rpm up here in cold-a$$ Mississauga, Canada. By the time the car has warmed up I'm sittin at just under 700, from the looks of it. THe only engine mod I have is an Injen CAI. When I was running stock, my idle once fully warmed up was a little higher, maybe around 800.
Old Feb 26, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
lol 100 RPMs? that is incredibly slow, INCREDIBLY slow....[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG] it is definitly your gauges.. otherwise Honda might not be selling Insights anymore [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 26, 2003
solar's Avatar
solar is an unknown quantity at this point
Your Tachometer is way off, no question, either your numbers aren't lined up or your Tach is not reading correctly. Your engine wouldn't run under 500 rpm, and if it possibly could, it wouldn't be smooth.
Old Feb 26, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
exactly, an engine running at 150 rpm shakes like the jeebies... My jeep and idle speed control valve problem and used to dip around there, and it was not pretty....
Old Feb 26, 2003
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
yeah dude, mine does the same thing and its fuggin pissing me off!
ive taken it to honda 3, and the "techs" there cant figure it out. im guessing it has something to do with the MAF sensor, but i could be wrong.
this is making me so mad, ive posted a couple of times about this but i cant get an answer.
hey jrock: does it seem like it chokes, coughs, then goes back up to 800 or so?
and i bet it happens when you get to a red light right?
Old Feb 26, 2003
mike0404's Avatar
mike0404 is an unknown quantity at this point
mine do the same thing.
rpm's drop down to 200..it hapened when i installed aem cold air intake..but i dont have no problem so far..
Old Mar 2, 2003
jrock2324's Avatar
I have no problem at all with it. No shaking at all.
Old Mar 2, 2003
Grey's Avatar
DIY King
Um... I've taken apart the throttle body (which controls the idle) and I don't see how installing an intake will affect the idle speed? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
You would have to hit the throttle position sensor really hard, or hit the idle air control valve really hard, or maybe move the air temperature sensor to a location that read the air temperature as colder than what was actually entering the throttle body. There's nothing else that would affect this. Simply installing an air intake should not affect the idle speed.
Multiple people are confirming this though, so what the hell is going on? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 2, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
If you have an unstable engine after installing intake, you probably didn't let your ECU program properly.
Disconnect your battery, then reconnect and start your car, leave it idle for 10 mins so the ECU and get used to the new air flow, then drive slow around for a bit. That should make your car run smoother.
As for 100RPM, the lowest block in the tach is 500RPM, it goes by 0RPM - 500RPM - 600 RPM - 700RPM, etc. So you won't see a 100RPM, you probably mean 500.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
