hose wont hold intake pipes together...
Old Feb 10, 2003
CbOiEX's Avatar
CbOiEX is an unknown quantity at this point
...i installed my injen cold air intake today and thought i did everything correctly. So after the install, i went to go test my new mod out and as i revved my car coming up on my street i heard a buzzing noise. I immediately get into my driveway and popped the hood...right then i saw that the hose that was holding the primary and secondary intake pipes together was loose and it came apart I didn't think anything about it and re-tightened the clamp..... until tonite when i went to seven eleven and while coming back i hear the buzzing again...when i got home i pop the hood once again and the secondary intake pipe was loose again....my question is if there are any ways to secure this because its starting to **** me off....thanks in advance.
Old Feb 10, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
was this buzzing noise kinda like a hisssssing?
Old Feb 10, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Did you bolt down the lower section tight enough? I just checked my CAI last night and everything was nice and secure. But of course the clamps won't hold the lower section on if there's play there. Plus the filter end of my lower section is really wedged between the bumper and wheelwell (more so by the rubber hose I got in there) so it doesn't move at all.
Old Feb 10, 2003
Snakes's Avatar
Snakes is an unknown quantity at this point
never heard of this happening before. i have a cai from aem and i've never had a problem with it.
it could be shaking loose. in which case, i guess you could try realigning the whole assembly (loosen bolts, move pipes into place, then tighten the bolts again). or you could have pressure building up inside the pipes (not sure how that would happen); in which case i'm not sure if there is anything else you could do other than tightening the hose-clamps (which you already tried). if the problem persists, i would just contact injen and ask for a new sleeve. if the new one doesn't work, contact them again and request a replacement cai.
Old Feb 10, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
I have a buddy with an Injen Cai on his car, not a 2k1, but he had the same problem. What he did, was take a metal punch, with a large flat end, and punched out the area near the end of the metal tubes, where the hose clamp goes, so that when you tighten the hose clamp, if it were to slip off again, it would have to go over those bumps. But if the clamp tightened enough it can't slip over the end. He said it worked for him, no more problems. Does that make any sense, or can I just not explain things?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 10, 2003
TeLLy's Avatar
That's a pretty good solution actually.
Old Feb 10, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
Mine did the same thing, so i went to orchard and bought 2 more hose clamps. 2 worked better then one. =)
carid
Nov 7, 2015 01:46 AM
Theshwartz35
Jul 17, 2015 11:13 PM
NoobyKid
Jul 13, 2015 07:53 AM
silentz
Jul 9, 2015 08:16 PM
Causemo
Jul 5, 2015 06:42 AM
