Floor Brace...help
Old Jan 18, 2003
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
Floor Brace...help
ok, im think of customizing a floor brace...but would it work? i was thinking of using 43mm thick polished steel...question is would it really work?would it really stop frame flex? cuz i don't wanna go through all that and to find out it would do nothing for our cars..but if i do go through and it works, i'll start a bussiness...lol
Old Jan 18, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
i see that aero speed makes one but i am not to shur that it works to well.. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 18, 2003
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
do you really want to add that much weight to your car. frame flex is really a problem for rear wheel drive cars due to the driveshaft. I would think it would be counter productive and a waist of money. correct me if I'm wrong but you would be good with some suspension upgrades. Not more weight.
Old Jan 18, 2003
Grey's Avatar
DIY King
True that. Although it probably does help a little bit. I wouldn't make it out of steel though. Make it out of some kind of hollow aluminum. Then it would be light and it would work too. It's all about hollow tubes and triangles yo! Mount it to two points on each side. Also stiffen it for buckling! That kind of bar would be good for a racing harness if you make it right.
Old Jan 18, 2003
Super Member
alrite thanx for the info guys.
Old Jan 19, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Well, for all you peeps that complained about their sunroof popping out of the well...
Guess what? Unibody cars are made to flex and when you change something in the car esp the suspension parts, you disrupt the balance of the car. You stiffen the springs, you will need to reinforce the car. A solid bar just where the end of the front seat rails are will do good. You should get it done professionally. I got a quote for a 6 point roll cage for $300(includes the center floor brace). They use a cromoly alloy bar. Which would be alot lighter than your steel. I would like to do it myself, but then I do not have the machines to balance my car at all four wheels. A cage will not help if your car is balanced and sysmetrical. Who is willing to pay for the balancing anyway. Its not like anyone here has the $500-$800 to get it done. Plus, I know left front (LCA)bushings are wearing out. I hate the on/off ramps in california. They all go in one direction.
I have my floor brace sitting my room. The brace is a little short(out cars are about 2 inches wider than previous Civics). I will post a fix for solution(one of them). We do not need the hump, that is why we can have a straight bar. Out exhausts veers right from the engine and not straight out like older civics.
mistahlorax13
21
Nov 18, 2015 12:47 PM
General DIY
Sep 25, 2015 08:02 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
