REVO help
Old Jan 3, 2003
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
REVO help
i installed my Revo SS yesterday took it for a drive and had to problems. but today it will not go into first or second gear. its too dark to look at tonite so i was wondering if anybody has any ideas on what the problem may be before i go out tomorrow to look at it.
Old Jan 3, 2003
PwN3d's Avatar
PwN3d is an unknown quantity at this point
take the center console out and check for something getting in the way. thats all i can think off right now.
Old Jan 4, 2003
Chapobapo's Avatar
Chapobapo is an unknown quantity at this point
not too sure if this would be the cause for your problem, but then again it could be... did you have your stick in gear when you installed it?
Old Jan 4, 2003
Sweetpants's Avatar
ok i looked at it, and the ball inside looks like it is coming apart. And wehn i try to put it in first or second the piece on the left does not move forward like it is supposed to.
Old Jan 4, 2003
ddrcivicex's Avatar
ddrcivicex is an unknown quantity at this point
If you have'nt fixed your ss I think the same thing happened to mine. there is a plastic guide that fits into the rubber binding that is around the tranny cable, it has probably come detatched. I had to tape the peices together ghetto stylr to the shifter plastic housing.Hope that helps
Old Jan 4, 2003
Sweetpants's Avatar
question about the revo, should the shifter, where the **** screws on, be able to twist? because i can spin it around. i think the plastic ball it sits in is broken because it looks like it is splitting open.
Old Jan 5, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
sounds like your part is broken... call revo,.... they should replace it with minumal probs
Niter1dah
Jul 20, 2002 12:25 PM
ChEe12iO
May 30, 2002 04:06 AM
Grey
May 7, 2002 08:38 AM
importspd
Mar 2, 2002 06:08 PM
SOHC
Feb 19, 2002 09:32 AM
