Q with clearing headlights..
Old Nov 30, 2002
smjkxriChy's Avatar
smjkxriChy is an unknown quantity at this point
I've attempted to clear my headlights today and i had to put my bumper back on in failure.. er sucks.
anyways, my question is that .. once i take off the bumper and start to unscrew the screws around the headlight to remove the headlight and the bracket that holds it [4 screws in total] - i seem to have A LOT of trouble unscrewing the screw on the bottom. it's sorta blocked by the metal bar through the middle of the car, and i tried using a socket wrench, but no luck .. nothing would fit right around it. how did you guys manage to get through that bolt? with what tool? and if you can give me suggestions .. i would appreciate it a lot. thanks!
Old Nov 30, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
socket wrench fits.. use the extention... its alit bit of a tight fit... and make sure not to bend to many fins on the radiator when u do..
Old Nov 30, 2002
smjkxriChy's Avatar
what size?
Old Nov 30, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i used a 6" extension I think.. it came with my 200 piece socket set
Old Nov 30, 2002
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
6" extention works just fine. $3 will get you one. No need to buy a $10 Craftsman
Old Nov 30, 2002
e30iS's Avatar
e30iS is an unknown quantity at this point
I did it on my friend's civic with no problem. Just used I think a 1/2" socket wrench and stuck that baby in between the metal. It's easier gettin it back in than taking it out.
-Jeremy
Old Nov 30, 2002
CarbonFly's Avatar
Go find some elbow grease!
Old Nov 30, 2002
smjkxriChy's Avatar
did everyone use size 1/2 with the socketwrench?
and btw .. thx for the tips!
Old Nov 30, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Yeah I was able to get mine out without a extension but when I did my buds lights I had to get a extension. But yeah I about gave up too when I couldn't get that screw out because I was living alone and everyone was at work so I would have to put my car back together to go buy that extension. Luckily my neighbor was home
You'll get it just get the extension and the hardest part will be the lights after that then your home free
Nick
Old Nov 30, 2002
bootlegskwirl's Avatar
bootlegskwirl is an unknown quantity at this point
Get one of those "as seen on TV" flexible screwdriver/drillbits thing. I got one for $15 and it works great for all those hard to reach places.
Old Dec 1, 2002
smjkxriChy's Avatar
i already have the extension, i still couldnt unbolt it .. none of the sizes would fit, it would be either too loose or too tight.
what size did you guys use?
Old Dec 1, 2002
Bayou2K1's Avatar
Bayou2K1 is an unknown quantity at this point
another question I can get the headlights off the car but cann't get them apart.
Old Dec 1, 2002
aetobatus's Avatar
n00b
aetobatus is an unknown quantity at this point
Quote
[hr]Originally posted by: smjkxriChy
what size did you guys use?[hr]
10mm
Old Dec 1, 2002
aetobatus's Avatar
n00b
these are the tools I used to remove my front bumper & headlights:
10mm socket
philips screwdriver
flathead screwdriver
6" extension (4"+2")
rachet handle
Old Dec 1, 2002
smjkxriChy's Avatar
ahhhhh thx ppl!!!
Old Dec 3, 2002
Quote
[hr]Originally posted by: Bayou2K1
another question I can get the headlights off the car but cann't get them apart.[hr]
You mean pry the 2 pieces a part? Use a hair dryer and a flat head screwdriver to pry away until you can get a grip on them
Nick
Old Dec 3, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: NickDaMans02Civic
Quote
Nick[hr]
Or you can just pop them in the oven. I had them in at 200 degrees (lowest setting) for like 10 minutes. I just cleared mine on Sun and had a hard time getting the glue soft enough with the hairdryer.
-Kre
brash99
Sep 29, 2015 08:42 AM
beanhead
Sep 24, 2015 12:04 PM
PunX
Sep 23, 2015 10:45 PM
