Turbo question?
Old Nov 27, 2002
Doug's Avatar
Doug is an unknown quantity at this point
Turbo question?
I have a 2k1civic dx i am looking into running a t3/t4 garret with sparco intercooler not sure about custom exhaust manifold wastegate and bov. would my car be able to take it would i need new pistons valves vlave springs? also would i be able to use some of the piping from my aem cai?
alright thanks
Old Nov 27, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Check all the turbo posts.....it's been covered....I don't believe theres an exhaust manifold out yet.......
Theres a few people on here that went FI.......And it depends what your boost is......1-8???....i think 8psi is max without harming your internals......
Old Nov 27, 2002
C2i0v0i1C's Avatar
SuperMODrizd
spearco intercooler
turbo link for 7thgens
as long as u dont go to far over 8 psi like he said ur stock insides should be fine
Old Nov 27, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
The turbo set ups for our cars aren't that bad, you are looking at some hidden cost tho. If you are going to do it tho you are going to have to have that piping bent for your car no matter what, you could reuse your intake but sense you already have to do pipe work,especially if you get the intercooler, just spend the extra couple bucks and have it all redone and sell the intake, I'm sure that would cover the cost of the extra pipe work.
Old Nov 27, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
do your fuel system first before you even think about what turbo set up youre running. anyone with a good working turbo 7th gen has had to modify the fuel system in some way. i know riceburner did stuff with fuel pressure regulators or something, but i chose to go with a full on return system.
Old Nov 27, 2002
XxJDMCivicxX's Avatar
I would have to agree with civicpunker since he just finished the first step of it, either way first thing you gotta get done is the problems with the fuel line then think of what turbo to use.
Old Nov 27, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
The fuel system we have is enough for up to 8psi with an additional injector and computer, or computer controlling larger injectors in the engine. Above that, the pump cannot pump fast enough to keep up. Besides, the engine can't take much more than 8psi before you start breaking things, so unless you're rebuilding the engine, there's no need to go return on the fuel setup or anything more than changing/adding injectors.
Mine was nothing with fuel pressure regulators, it's a Haltech F5 running an additional GReddy 460 injector placed before the throttle body. Still stock FPR, fuel pump, and lines.
Old Nov 27, 2002
we actually used an aftermarket fuel pump in the tank. i think b&m makes it but they said it took a while to modify whichever one they used. now i hear a pretty cool "whiiiiir" coming from the back, but hopefully itll quiet down once my seats are back in there.
Old Nov 27, 2002
First to spool
Yeah, that's what I'll be doing when I do build the engine, there's a B&M that, with slight modifications, can me made to work perfectly.
Could have done it now, but I'm not running over 8psi until I rebuild the engine anyways, so not necessary yet.
Old Nov 27, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
anyone got any comments on the post i made about the hybrid 1G-GTE toyota piston/ B16 rod combo ? it seems to work wonders on the D16. but what about us?
Old Nov 27, 2002
First to spool
Different engine, different combustion chamber dimensions.... I seriously doubt the exact same thing that worked on a D16 will work on a D17.
Old Nov 27, 2002
d16 spins oppsite as well
Old Nov 27, 2002
2k1civic.com O. G.
i believe the only thing keeping us from running higher levels of boost is fuel and our weak pistons/rods. the D16 pistons have a bore of 75mm as do ours. the only thing that is different is the stroke. i beleive our stroke is 94.4mm and the D16 is 90mm.
that piston/rod combo works on the D16 with minor mods like thicker head gasket and notching of the bottom of the block so the B16 rods will have enuff clearence. since our stroke is longer might require more mods for it to work. just thought it might be a cheaper alternative to gettin custom made piston/rods? wut other rods could work?
oh and what does the motor spinning the oppsoite way have to do with the piston/rods?
Old Nov 28, 2002
Doug's Avatar
so could i use a jet chip and like some rc engineering injectors for now?
Old Nov 28, 2002
i dont know if it had anything to do with pistons/rods, i know its just a difference that allows us to not use anything from the older civics, like and OBDI to OBDII conversoin.
Old Nov 28, 2002
err, other way around...OBDII to OBDI...i cant think this morning
Old Nov 28, 2002
Doug's Avatar
could i make a hole in my kamikae header i have now for the inlet piping?
Old Nov 28, 2002
Grey's Avatar
DIY King
You might want to read my partial DIY. Just click on the link in my sig. It explains a lot, but not in too much detail. I'm still working on it...
Old Feb 4, 2003
C2i0v0i1C's Avatar
SuperMODrizd
if JET remaps ur ecu and u over rev without valve work than SMASH. START ALL OVER
that is with a turbo setup
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
