Headlight wireharness
Old Oct 25, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
Has anyone upgraded their headlight wire harnesse yet? I just got mine in the mail and i was wondering if anyone has done it before, i would like a little advise on how to get started. Thanks forum.
Old Oct 25, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
Where did you get yours from?
Old Oct 25, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
I got JDM gun metal head lights a few weeks ago.
They were really easy to install. Just take the whole front bumper off to do this. believe it makes the process a lot easier. after you've installed it make sure that the head light beams line up correctly, aftermarket head lights tend to do that sometimes. best way to check for that is at night face the car at a wall and you can tell from there wheather or not the head light beam line up correctly..
Old Oct 25, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Quote
[hr]Originally posted by: ducksause
They were really easy to install. Just take the whole front bumper off to do this. believe it makes the process a lot easier. after you've installed it make sure that the head light beams line up correctly, aftermarket head lights tend to do that sometimes. best way to check for that is at night face the car at a wall and you can tell from there wheather or not the head light beam line up correctly..[hr]
Uhm. That's not what he's asking. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Have you had any problems with your Gunmetal headlights? Where did you order them from? No fogging or anything?
Anyway, to install that wire harness just pull the wires out of the old one and stick them in the new one remembering where they do.
Old Oct 25, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I'm not 100% sure but I think you take your new harness and it connects directly to the battery with thicker gauge wire, then you take your old plug that plugged into the headlights and plug that into the new harness. It should have some kind of relay that directs the power from the battery to the headlights through the thicker gauge wire, instead of the stock wimpy wire... it should be an easy install, just cover all your wires with wire loom so it looks professional. Let us know how it turns out...
Old Oct 25, 2002
TYPE7RS's Avatar
Quote
[hr]Originally posted by: IDQcivic
I'm not 100% sure but I think you take your new harness and it connects directly to the battery with thicker gauge wire, then you take your old plug that plugged into the headlights and plug that into the new harness. It should have some kind of relay that directs the power from the battery to the headlights through the thicker gauge wire, instead of the stock wimpy wire... it should be an easy install, just cover all your wires with wire loom so it looks professional. Let us know how it turns out...[hr]
yeah, i thinks that's it ! i was looking at the wire harness tonight and i found a spot to plug in the old wires, a ground for each new bulb plug, battery terminal connections and two fuse connector (or whatever you want to call them). Thanks, i just wanted a second opinion. Once i'm done, i'll let you guys know with some pics, and i'll show you my new blue dash lighting although it still needs a few adjustment before i'm done with it.
oh, and JDog, mine came in through airmail from taiwan.
Old Oct 27, 2002
TYPE7RS's Avatar
yup, it was a five minute installation process, the hardest part was trying to get the nut i drop into the engine bay once i get some wire loom, i plan to post some long over due pics into the member rides, hopefully before my car gets anymore dents in it
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
