timing on car mess up?
Old Oct 22, 2002
nongv's Avatar
nongv is an unknown quantity at this point
i just put in my cam gear and advanced it 3 degree but i don't know if i did it right. first i lossen the three screw then instead of turn the bolt where it holds the cam gear, i turned the crank instead and the timing belt and just the part of the cam gear where the belt is held on moved all the way until it hit the three bolts that i loosen and then the whole thing moved. i have figure it out that i was suppose to move the bolt where it held the cam gear in place to advanced and retard it. so i put it back to 0 degree. did i mess up my timing? how can i check if my timing is right? can the timing gun work for our car because our car doesn't have a spark plug wire for it to hook up to. if i take it to a shop can the teel me if my timing is off?
Old Oct 22, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
dude, thats what happend to me, but i honestly think that it didnt do anything but throw your adjustment to one side. i put mine back and the car worked, but my problems occured in the long run, cuz after a while, the car starts performing differently... and starts having wierd symptoms caused by the timing/cam gear. if i were u, id keep the timing settings on the gear close to 1 or 2. its suggested by all tune shops not to exceed 2 degrees with out head/cam work. any more and you will be messin with ur timing more than u wanna be. some people said they have adjust to 5 degrees advanced, but that is exactly what u do NOT wanna do...
Old Apr 10, 2003
HOFFKIT's Avatar
HOFFKIT is an unknown quantity at this point
same thing with me i have a ticking noise when the engine is cold now
Old Apr 11, 2003
triryche's Avatar
triryche is an unknown quantity at this point
Ok I want to try to adjust my cam gear and setting this. If any have the correct setting + or -?
Old Apr 11, 2003
cdmx's Avatar
doesn't it make a whirling noise with an aftermarket cam?
Old Mar 16, 2004
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
HOW DO YOU ADJUST IT TO FACTORY SETTINGS
mattdoc
Mar 14, 2017 12:10 PM
dragonsblood
Apr 27, 2015 12:28 PM
Thees1
Apr 14, 2015 08:23 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
CivicHX01
Oct 22, 2001 11:11 AM
