Kaminari Kit Question
Old Oct 3, 2002
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Ok, I'm finishing the install of my Kaminari Kit tommorrow. As some of you know, I didn't get any instructions with the kit.
Now here's my question...
My side skirts, one of them (I forget which one), had 3 holes drilled into it for undermounting. The other one did not. So I just figured they forgot to do it on one of them, so I drilled 3 holes into the side skirt.
Now I was thinking that maybe it was done on purpose...incase there is some lines running down the side of the car. So if you have a Kaminari Side Skirt on your car, can you take a look at both sides and see if they have any screws into the underbody of the car. Both sides? Just one side (if so, which side)?
If I dont get a reply tommorrow, I'll give Kaminari a call just to be safe.
Thanks, will post pics. Front end with grille is on....looks very nice and fit PERFECTLY....even better then when I dry fitted it.
Matt
Old Oct 3, 2002
DcatStylee's Avatar
DcatStylee is an unknown quantity at this point
Maybe they are holes for water draining. Mine retain water like beeeeeeeeeeeeeeeeeeeeeyotch.
Old Oct 3, 2002
They have "vents"
Matt
Old Oct 3, 2002
jer2k's Avatar
jer2k is an unknown quantity at this point
i just checked my kaminari sides and the only holes i have are the ones for mounting on both sides
i have four screws on each side
good luck with the rest of the install (sides ar the hardest)
Old Oct 4, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
Quote
[hr]Originally posted by: jer2k
good luck with the rest of the install (sides ar the hardest)[hr]
u got that right
i had to redo mine like 5 times
Old Oct 4, 2002
bake's Avatar
bake is an unknown quantity at this point
the guys that painted mine installed mine and they drilled holes on the top so it supposedly would be more sturdy.......now ive got 2 screws on the top of the skirt that rub the bottom of my door that scrapes and is starting to rust the top of the screw
civic98?
Aug 13, 2015 01:32 AM
j-chest
Jul 31, 2015 01:18 PM
DerbyDad03
Jul 27, 2015 11:34 AM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
