Painted Int, will it last?
Old Oct 3, 2002
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Whats up all. I've read countless posts about how people painted their trim. And I'm thinking about doing mine. What I want to know is does it last?? Those who have done it please respond. How does it hold up to scratching, flaking and heat?? Thanks for the help. And yes, I've searched and found no posts about long term looks.
~nick~
Old Oct 3, 2002
speedracersong's Avatar
i painted mine like 6 months ago.
so far its pretty clean.
the paint did chip off when i put some stress on the middle console when i taking it out. i guess i have to repaint.
but all and all its a recomended diy
Old Oct 3, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
i did my trim a long time ago..must be close to a year...looks just like the day i did it...through the freezing cold winter and boiling hot summer. i followed the instruction in the DIY exactly
Old Oct 3, 2002
notsodiseased's Avatar
notsodiseased is an unknown quantity at this point
ive had my done orange and blue for about two months now,,no problems,,, i put helllllllla clear coat on it so that helped,plus this south texas sun is killer but yea if ya do it right and take lots of time youll be okay
Old Oct 3, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
The key is to make sure the paint adheres to the plastic trim. I used a non-metal surface primer to accomplish this, and after about three months so far so good.
Old Oct 3, 2002
BOYTOY's Avatar
BOYTOY is an unknown quantity at this point
I sanded , primed, used two coats of silver, 3 coats of clear, when to mask off (with the blue tape) where i just painted silver and pulled up the tape and it took EVERYTHING off, right down to where i started........... If you really want it to stay you have to use some type of bonding agent, it melts the plastic and preps it so it will actually stick, and not flake or chip...or.... I just sprayed my trim pieces with this Vinyl dye aresol .........it came out really smooth and it actually stuck, just to see how good it was i took DUCK TAPE and pulled it up and it didnt take anything off..... PLastikote seemed to work for other people but i had alot of problems with it
Old Oct 4, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Yeah, I highly suggest using the clearcoat because if it is in a high-sun situation, the paint will fade real fast. I put clear coat on mine and not only does it look shinier, it helps protect it too...the clear coat will slow it down a bit...
2Hottie
Old Oct 4, 2002
iamboo's Avatar
Retired - SoCal FI Mod
KEY POINT !!!!... listen... cause i know what i'm doing... i've done this over and over again on other peoples cars !!!!
don't just put 2 coats... put many many LIGHT coats.... the paint will stick better... this goes for BOTH primer and paint and clear coat... light means you won't be able to see the paint right away... but as you give it more coats the better and cleaner it'll look...
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
