Easy Turbo question?
Old Oct 2, 2002
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
I was hoping someone could explain to me how you turn bosst up on a turbo? I just don't understand if it's a mechanical piece how do you do this? I know a supercharger/blower you can change pulleys.
Thanks
Old Oct 2, 2002
prototype's Avatar
x-factor
turbo uses exhaust.....the exhaust come out of the head and into the turbo....once a certian amount of pressure fills the turbo it releases it. the affect of that is boost. you can adjust how much boost the turbo can hold by a boost contoller more air in the turbo=more boost. hope that helps....happy boosting
Old Oct 2, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
Yep- a turbo has a "brain" if you could call it that, that can be adjusted. Like if you stuck a vacum cleaner on your header to pull the exhaust fumes out faster, and the vacum had adjustable settings for more suck.
Old Oct 2, 2002
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Actually, ther is a waste gate. The turbo sucks a certaint amount of air in at certaint throttles no matter what. To control the boost you adjust the wastegate. Once the tubing for induction is filled (the tubing from turbo to throttle body) with compressed air the wastegate dosn't let anymore than what you set it at, such as 5, 7, 9 pounds of boost etc.. Then when you let off the throttle the turbo stops producing boost and the boost that is left in the tubing is released through the blow off valve. I hope you understand what I am saying. I have a turbo on my civic. Hope I could help ya.
EDIT: The wastegate is the boost controller.
Old Oct 2, 2002
ExRacer's Avatar
ExRacer is an unknown quantity at this point
um....boost controller.[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Oct 2, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
the way to control a turbos actual boost pressure is to control how fast it spins. this is the job of the wastegate. what it does is control how much exhaust goes to the turbine of the turbo, and how much bypasses it. The more you let into the turbo, the faster it spins, and visa versa. The wastegate can be one of two basic types, internal, and external. internal are usually smaller and are usually mechanically adjusted by means of a screw or spring change. the external ones can generally handle higher boost pressures and generally are quite large and expensive. turbos can spin in excess of 150,000 rpm so if they go slower, less boost, faster, more boost...etc
Old Oct 2, 2002
greg2k1's Avatar
Thanks guys that helped a lot. So does this mean that a Boost COntroller is actually controlling the wastegate to dteremine the amount of boost the trubo will make??
Old Oct 2, 2002
prototype's Avatar
x-factor
yes....more psi more boost harder the turbo hits...if you dont have internals u WILL break something thats why the guys on hee with turbos only run 5psi of boost....i ran about 15 psi on my eclipse and was fine b/c i did the rods and pistons....and if i changed the compression i would have been able to run about 17 lbs
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
mjdiaz89
Jun 21, 2016 09:26 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
NoobyKid
Jul 13, 2015 07:53 AM
