[ Cylinder Head Question ]
Old Sep 9, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
Does anyone out there know yet whether the k20 cylinder head is compatible with the d17?
The engine rotational direction shouldn't affect the head at all....
I guess this would be a good question for the certified honda tech's out there....
Old Sep 9, 2002
orso's Avatar
orso is an unknown quantity at this point
d17 SOHC K20 dohc
Old Sep 9, 2002
Simkin's Avatar
The head swap would convert our sohc to a dohc, that's the whole point of the head swap...
Old Sep 9, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
no. it doesnt fit. and yes the engine rotation affects the head.
Old Sep 9, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
yeah, but the whole displacement difference along with the total size of the heads themselves, i don't think the new head will match up with the d17 block. But i'm not a certified Honda tech. I could be wrong.
Old Sep 9, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
i HIGHLY doubt the head would fit.....even if it did, i cant even contimplate the other things that would be required for that to work..uggh!
Old Sep 9, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
It does not fit. The oil and water ports to not line up. The head bolts do not line up. The head spins in an opposite direction of the motor, SO the cams are incorrect.
Swapping heads only worked when you had the same block as on a B series engine.
159
Jul 5, 2015 09:54 PM
McLean
Jun 13, 2015 10:32 AM
Tim1959
Jun 3, 2015 08:15 PM
Jun 2, 2015 11:54 AM
viper775
Dec 9, 2001 10:52 PM
