hp header problem... need ideas
Old Sep 7, 2002
JKEEZO's Avatar
JKEEZO is an unknown quantity at this point
alright... i just installed my hp header w/ high flow cat and i have a little problem
where the header and the cat fit together, there is an "ok" size leak.... the hook for the hanger is on the bottom if you need to know
also, the header kind of hits the metal bar that you jack your front end up on... im thinking of just putting a soft metal there to stop the noise...
any suggestions would be great
oh yeah, i took it for a test drive and it gave me damned good gains
Old Sep 7, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
can we say missing gasket? There is no such thing as an "okay size" leak. There are only ones that "arnt as bad".
Old Sep 7, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
How did you do it??? I couldn't get it to fit. If you shaved any mounts, PLEASE post pics for me. If not then explain what you did. Thanks. Also make sure you got the gasket from honda for between the header and cat. I got it for about $14 if I remember right.
Old Sep 8, 2002
ExRacer's Avatar
ExRacer is an unknown quantity at this point
its the gasket...
Old Sep 8, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
And that header with high flow cat is the shizz isn't it? You've now been granted to run 15s. What else do you have in terms of engine mods?
Old Sep 8, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: NBPCivic
How did you do it??? I couldn't get it to fit.[hr]
Aren't you supposed to lift the engine to get it on? It only doesn't fit properly because it's a "race" header.
Old Sep 8, 2002
JKEEZO's Avatar
i didnt have to shave any mounts at all, it was a biatch to get it in but its just a tight squeeze to fit the header in through the bottom of the engine bay
ill get the gasket
Old Sep 8, 2002
JKEEZO's Avatar
Quote
[hr]Originally posted by: SoNiCcIvIc
And that header with high flow cat is the shizz isn't it? You've now been granted to run 15s. What else do you have in terms of engine mods?[hr]
in the sig (members page) \/
Old Sep 8, 2002
JKEEZO's Avatar
well, im going to head over to my friends house to fix up the leak, do you think i could buy the gasket at my local honda dealer???
after i fix it up ill post a review on it... for now i can tell you hp++ and sound (with my magnaflow) +++++++ (it actually sounds like... powerful [IMG]i/expressions/laugh2.gif[/IMG] )
Old Sep 8, 2002
NBPCivic's Avatar
Why don't you explain exactly what you did to get it to fit instead of just saying it was a tight squeeze or whatever. I have the part sitting here because I couldn't get it in. Please be more detailed so that you can help us all figure it out. Thanks!
Old Sep 8, 2002
JKEEZO's Avatar
Quote
Why don't you explain exactly what you did to get it to fit instead of just saying it was a tight squeeze or whatever. I have the part sitting here because I couldn't get it in. Please be more detailed so that you can help us all figure it out. Thanks![hr]
im assuming you are talking about the header... alright i have a 2k2 ex automatic, and this is one of the cars that you do not need to modify whatsoever (no shaving engine block or anything)
in order to get the header into place, i jacked up the front of the car, my friend went under the car.... he put it up from the bottom of the car through the engine bay at an angle and it was an extremely tight squeeze
sorry, i dont know if you are asking about the shaving the engine mount problem or the actual installation of the header
i just fixed the leak with the stock gasket and now im going to get pics
Old Sep 8, 2002
NBPCivic's Avatar
I also have a 2k2 ex Auto. we couldn't get it to squeeze through from the bottom. Did you slide it in at an angle, like, was the drivers side of the header fit through first then you brought it up at an angle or what. IF you could give some info that would be great. We tried removing the motor mount and jacking the front of the engine up too and still couldnt get it to fit through.
Old Sep 8, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
Quote
[hr]Originally posted by: JKEEZO
Quote
i just fixed the leak with the stock gasket and now im going to get pics[hr]
What are the other cars that need no modification (LX Sedan Auto Maybe?)? I've been trying to find info on the headers everywhere, but no luck.
Old Sep 8, 2002
JKEEZO's Avatar
Quote
[hr]Originally posted by: alienmonkey
Quote
Quote
What are the other cars that need no modification (LX Sedan Auto Maybe?)? I've been trying to find info on the headers everywhere, but no luck.[hr]
i dont really konw what else it will fit, i just found out someone had them on my car and they worked so i bought them (and yes they are hard to find)
Old Sep 8, 2002
JKEEZO's Avatar
Quote
I also have a 2k2 ex Auto. we couldn't get it to squeeze through from the bottom. Did you slide it in at an angle, like, was the drivers side of the header fit through first then you brought it up at an angle or what. IF you could give some info that would be great. We tried removing the motor mount and jacking the front of the engine up too and still couldnt get it to fit through.[hr]
alright, first we jacked up the front end, and put it on a jackstand (because the jack got in the way) (also... this should be before you put the high flow cat on because that will get in the way to, or you can just move that aside for a minute)
alright, next we tilted it so the right side of the header (if you are looking from the front of the car to the back of the car) was higher.... then we just kept pushing and moving it around and it barely squeezed in
hope this helps
Old Sep 8, 2002
JKEEZO's Avatar
just put a pic of my engine bay here
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Paiige
Jun 24, 2015 07:17 AM
Red_Chaos1
Jun 21, 2015 01:12 AM
EK_Eddy
Jun 6, 2015 07:31 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
