question.... plz help....
Old Jul 16, 2002
buddyclubcivic's Avatar
buddyclubcivic is an unknown quantity at this point
do you guys know how to take off the backseat?? is there any screw that hold the backseat or do i just pull it out?? i have to take the backseat out in order to wire all my stero cable. thanks
Old Jul 16, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Sad...so sad....try searching you @#$#$%!!!!
Old Jul 16, 2002
robbclark1's Avatar
Retired suspension supermod.
you have to pull the sides of the back off first then take the seats out. I know toastyghosty has a DIY with pics but his site is still down. Do a search too and u will get your answers.
Old Jul 16, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Remove the back seat bolt(inbetween the bottom seat and the upper part), and the lift up on the seat on both sides. The seat will pop right out. =)
Old Jul 16, 2002
JCap's Avatar
JCap is an unknown quantity at this point
1. Fold the seats down.
2. There is a little velcro cover on the smaller section (near the middle). Lift it up and there a bolt to remove.
3. Once the bolt is removed, lift the small section up and out of the bracket
4. There are now (I think) two bolts to remove for the larger section (on the same bracket that had the other bolt). Remove those and the large section can be lifted up and out of the brackets.
5. There is only one bolt holding the seat cushion. It's right in the middle once you remove the seat backs. Remove that and the seat can be popped out of it's plastic holders (just lift).
5-10 minutes.
Old Jul 16, 2002
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: APS
Sad...so sad....try searching you @#$#$%!!!![hr]
damn tahts harsh....
Old Jul 16, 2002
OPGForce's Avatar
OPGForce is an unknown quantity at this point
Click Here
Old Jul 16, 2002
vino's Avatar
vino is an unknown quantity at this point
pretty much common sense if you ask me....but if you just cant do it searching is the next step
Old Jul 16, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Yo APS, I think you need to chill the fvck out. Daaaamn. [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
LilNic13
Nov 28, 2015 10:26 AM
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
jody501
Jul 10, 2015 11:01 AM
Myredjonda
Apr 14, 2015 07:00 PM
