problem with fitting on injen CAI help...
Old Jul 14, 2002
Alex1's Avatar
well i did everything, put the rubber cushion, cut the 3" half circle on the splash guard, but the bottom corner end of the plastic tray of the battery is rubbing against the lower pipe. it slightly sits on the pipe. is anyone else's set up like that? i have a 2k1 EX coupe.
Old Jul 14, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I just didn't bother putting the battery tray back in. I also put another rubber cushion between the steel battery shelf and the intake pipe.
Old Jul 14, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
Yeah will help you out when you show us pics of illwills turbo?
Old Jul 14, 2002
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
yea..... show us pics.... or admit that his turbo is shizt......
Old Jul 14, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
well I will tell ya that I have the same problem too. So it is nothing to worry about.
Old Jul 15, 2002
Alex1's Avatar
look guys the turbo exists and is running in the car. i dont have to prove anything to u. if u are interested in buying the kit WILL assembled then well have a look at it together. only if serious. otherwise keep dreaming of a turbo because to u, it never existed. to us, its spankin SI's. 6thgen SI's that is.
Old Jul 15, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: alex1
look guys the turbo exists and is running in the car. i dont have to prove anything to u. if u are interested in buying the kit WILL assembled then well have a look at it together. only if serious. otherwise keep dreaming of a turbo because to u, it never existed. to us, its spankin SI's. 6thgen SI's that is.[hr]
I personally thing you are a liar. Why would we buy somthing wtih no pics? Stop bragging about the turbo cause there is none, so STFU.
trevor
Nov 16, 2001 05:02 PM
trevor
Nov 15, 2001 05:59 PM
se7en
Nov 12, 2001 10:13 AM
Daniel420
Nov 9, 2001 08:36 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
