diy- transmission fluid
Old Jul 2, 2002
AnotherDopeStyle's Avatar
AnotherDopeStyle is an unknown quantity at this point
i saw one for an oil change, does anyone have one for the transmission fluid?
Old Jul 2, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
similar procedure, drive the car to warm up the trans, jack up the car, remove the bolt for the transmission (to find it look for the transmission and a size 12-14mm bolt on the bottom) and let the fluid flow. i would only used honda rated fluids only especially if your car is new.
Old Jul 2, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
the drain bolt is size 3/8 which you would use a rachet for which is near the front of the car on the very bottom of the tranny....depending on if it is a manual or auto....manual you have to remove the 17mm bolt that is about 4 in above the drain bolt. auto you just pull the dipstick out and fill from above.
Old Sep 9, 2002
SilverTrouble's Avatar
SilverTrouble is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
can't decide which one is the drain bolt... any pics? mine is the auto...
Old Sep 9, 2002
1955's Avatar
PLEASE DONT MESS WITH THE FLUID,,THEY DONT NEED ANY ATTENTION AS MUCH AS ENGINE OIL,,DO IT AT UR OWN RISK,,DONT SAY 1955 DIDNT TELL YA.
Old Sep 10, 2002
[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
i'm done with 36000 miles.. i think i MUST change the fluid... any pics about which is the drain bolt?
Old Sep 10, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I tried reading the manual but it doesnt say much.. I have a manual and all it says is how to check the trans fluid. It says to unscrew the trans bolt under the car and put your finger in the hole to feel the level. Well I did that and the fluid starts pouring out! I'm like WTF? Hopefully they overfilled it otherwise its low now.... And if thats the case how are you supposed to completely drain it then if the hole is above the level of fluid? I am majorly confused, somebody please help! Hopefully there is another bolt that I am missing or something....
Old Sep 10, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
IDQcivic: there are 2 bolts, one is higher than the other. The upper one is for checking the level, and the lower one is for draining it out completely. It is normal for the tranny to be a little over-filled, and gush out when you check the level like this, so don't be alarmed.
Old Sep 10, 2002
IDQcivic's Avatar
OK thanks, I'll have to look again. I bought these magnetic drain plugs and I put the oil one in already but when I pulled out the trans plug the hole was too big, maybe when I find the right drain plug then the magnetic drain plug will fit that too because now I have an extra!
Old Sep 11, 2002
RE's Avatar
RE
RE is an unknown quantity at this point
Quote
[hr]Originally posted by: 1955
PLEASE DONT MESS WITH THE FLUID,,THEY DONT NEED ANY ATTENTION AS MUCH AS ENGINE OIL,,DO IT AT UR OWN RISK,,DONT SAY 1955 DIDNT TELL YA.[hr]
Seriously speaking, transmission fluid serves almost the exact role of engine oil. Changing the transmission fluid can only have positive effects. Even for a new car, you should change the transmission fluid fairly early because there will be some minor debris comming from the gears settling in. I plan to change it soon as my car reaches 7000 miles.
Old Sep 11, 2002
ekwc's Avatar
ekwc is an unknown quantity at this point
Hi all,
For automatic cars, the bolt have a square shape hole is the drain plug. I've changed my ATF with Mobil-One-ATF for three months (40k now). My car runs smoother than before and my car sounds better too. Our cars come with a stock magnetic drain plug for automatic and it looks really nasty when I first removed it. It has a layer of metal particle around the plug. Also, our cars don't have filter for ATF. So, I will highly recommend you to change your ATF.
*Note: Your need about 3 qts ATF.
ekwc
Old Sep 11, 2002
thanx ekwc..
i'll change it this weekend.. i've already bought honda ATF....
Old Sep 13, 2002
1955's Avatar
okok..i cant argue with u cool folks but here is what the owner's manual recommended,change auto/manual trans fluid at 120k miles ,for auto,at 72 months regardless the mileage.fluid capacity is 2.9 US QT,IDQ i can answer your question while i am here.the inspection bolt for fluid level is 44N-m,torque to 33 ft lbs and just below that,is the drain plug bolt 39N-m,its torque at 29ft lbs,the correct fluid level is just at the openin of inspection hole when u fill the fluid in,,make sure u do it slowly and have a person to make sure u stop the fillin when the fluid start to sip out of the inspection hole,the capacity for the fluid change is 1.6 US QT.good luck
OptimisticWay
46
Oct 15, 2015 02:16 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
Jul 12, 2015 11:54 AM
