OK WTF!
Old Jun 23, 2002
civicvtec1ps's Avatar
Search and Learn
OK WTF!
Old Jun 23, 2002
Search and Learn
Old Jun 23, 2002
Captain's Avatar
Captain is an unknown quantity at this point
HHHHHHHHHHHMMMMMMMMMMM[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 23, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Im thinking a grounding problem what do you guys think?
Old Jun 23, 2002
frekyjason2002's Avatar
frekyjason2002 is an unknown quantity at this point
yeah check ur grounding wires bud.
Old Jun 23, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
this is the only thing i cna think of is that the little rubber piece that u get is supopose to go in place of the bolt that held a bunch of the ground wires on so either that might be loose or somehting else.
Old Jun 23, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Ok, i talked with ps1 the other day, we chat regularly cuz we live kinda close, I already had him install a washer on teh inside of the vibramount so he has one on each side, then install teh mount so the washer presses flat agaisnt the ground wires and makes a more solid connection, and hes still having a bad ground problem. Does anyone else know if perhaps he needs to get a wire brush and sand around on the frame where the plug goes in? I had the same problem when i installed mine, but after i put a washer on to help make the ground, everything started working fine.
Old Jun 23, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
I have an SRI with no ground. Should I be worried? Do I need one?
Old Jun 23, 2002
mikalem's Avatar
mikalem is on a distinguished road
It's not a problem with the SRIs, the problem is with a rubber spacer that attaches to the lower pipe by the fender. Yeah, it's most definately a grounding problem, I have issues sometimes with my car when it rains but it's gone away now and I don't have the problem anymore..... just make sure that the wires are directly touching the frame of the car, then put a washer over them to secure it down. Wirebrushing the area couldn't hurt either. Good luck!
Old Jun 24, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
Diaelectric grease- it is very usefull, and just might help!~
Old Jun 24, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
i installed my injen cai other day and have had no probs at all. The only time my blinkers went nuts in when i blew a bulb..THEN the blinker would blink like it was on speed!!
hmmm
PeArLhOnDa
meicalnissyen
Sep 25, 2015 12:12 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
hatch90
Sep 3, 2015 08:45 AM
alinaray
18
Aug 24, 2015 01:04 PM
GritzNGravy
Aug 19, 2015 03:03 AM
