Light up light switch. need help.
Old Jun 16, 2002
Duckor's Avatar
Duckor is an unknown quantity at this point
doh, that didnt work
-----------_
-----------\ \(off now)
_______\ \_______
|_______________|
|_______________|
|_______________|
heh, that took a while.
This light is a glowing red one that should turn on when i want the lights on.
what i can't figure out is how to make the switch glow.
how would i wire it? 1+ 2grounds?
2+ 1 ground? which would go where?
I tried a few combinations.. left the positive where it was and 2 grounds..
the 2nd ground started sparking like mad and melted the wire. except that it didnt if the switch was glowing.
above is currently how i have it set up and the light switch wont glow unless i figure out how the 3rd wire goes and where.
im not even sure the wires i have setup now is correct, but it works. it doesn't specify which is + or - or what ever the 3rd is.
it's a 12vdc switch for sure.
Old Jun 16, 2002
Duckor's Avatar
omegablue - it's a 12vdc, should of mentioned that before, thanks
Old Jun 16, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Ok first thing you HAVE to make sure of is that you have a lighted switch for a 12/14 volt dc current. I had that problem before until i looked at the box the switch was in from Radio Shack and realized I bought the one for a 110 volt ac current. The LED insinde the switch is set up to light at certain current draws, and if you have a 110 volt lighted switch, teh 12 volts provided from your car battery will NEVER be enough to light it. If you arent sure what voltage the switch is, easiest thing is to jsut run out and buy some other ones your sure are for a 12 volt dc source for a few bucks.
Old Jun 16, 2002
Ok, the if your Sure that its the right voltage for the LED in teh switch then usually the only other thing i can think is that the ground prong for the light feature is usually copper or brass and the other 2 are silver or nickle. If you run the lead into the lead next to the ground lead, and then run the ground lead to a grounding point, the switch will always be on (thats the way the switches are i have) and if you run the lead into the far prong, the switch will only light when you turn it on. Im assumeing that you know HOW to wire a switch and that your just concered with the actual lighting of the switch, but from how it sounds youve already trid all teh possibilities so my best guess is that the light is a dud inside and just take it back to exchange for another one. It happens all the time.
Old Jun 16, 2002
Duckor's Avatar
i can make the light go on in the switch, its just that if i have it set like that and switch it to off, it sparks like hell and the wire melts.
(this setup is 1+ and 2 grounds) could it be that im using a bad ground?
Old Jun 16, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
on the switches i got from radio shack, the load was in the center, and that was a +, then one side was a ground and the other side was a constant +
Old Jun 17, 2002
sham01ski's Avatar
sham01ski is an unknown quantity at this point
switches should be no big deal but one thing I had as a problem on my jeep was make sure that the ground that you choose for the switch to make it light up is strong enough. sometimes if the ground is not strong or if it is painted it also wont let it lightup. besides that omega sums up all there is to know about switches
Old Jun 17, 2002
Duckor's Avatar
i dont think i tried 2 +'s yet... i ran out of wire.
stryder12
Jun 30, 2015 08:33 PM
NukeSilo
Nov 20, 2001 05:17 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
wawacito
Nov 5, 2001 03:32 PM
meels808
Nov 5, 2001 09:15 AM
