rear lower tie bar?
Old Jun 12, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
rear lower tie bar?
if i dont jack the car up, can i just installed when the car is flat sitting on the ground? what tools do i need?
cuz i am scare that when i jack up the car, when i tight the nuts and bolts or loosen them, the car might drop and kill me
Old Jun 12, 2002
VNlilMAN's Avatar
The Standard One
i think its always best to use jack stands when working under the car
Old Jun 12, 2002
plastic's Avatar
plastic is an unknown quantity at this point
is it deja vu or was this thread posted not long ago... but yeah, jack your car up, its easier.. even if the car is on the ground, it won't collapse. it would just be harder to get the bolts in place
Old Jun 12, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
ok veyr important. YOU MUST JACK UP THE CAR. becuase the bolts where ur going to put the lower tie bar holds the tires to the car when u take them bolts out the lower control arm that holds the tires in will shoot out of socket. So u must jakc up the car. U will see what I'm talkign abotu when u do it but u must jakc the car up trust me.
Old Jun 13, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
Well I just recently did this and I agree "Ace Kicker " jack the car up unless you want more problems I found it easier to remove the rims because then the control arm was not as to put back into place since the weight of the wheel was not fighting you . but do it wich way is easy for you .. just a suggestion about removing the rims and make sure you torque them to 40 ft lbs. thats waht I was told from the dealer
Old Jun 13, 2002
Booohahaha's Avatar
BAD MON
yea fob dont use the jacks that came with the car man
hahaha mine got twisted and destroyed hahaha
need to pick a new one!
Dorval Andre
May 1, 2015 09:37 AM
bluecoupe
Dec 19, 2001 10:08 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
