Aftermarket Springs/Coilovers...Do I need Camber Kit?
Old May 9, 2002
Ghost's Avatar
Ghost is an unknown quantity at this point
Hey, I am seriously considering either installing new springs or coilovers on my new 2002 EX. I would like to drop the car somewhere around 2.5 to 3 inches. With this much of a drop do I need a camber kit? Also if you install the camber kit should you also take the car to be aligned after the drop? I am only posting this because I read through the other entries in the forum and saw no concrete answer and I am new to the mod scene. Also the equipment I am considering are neuspeed race springs, skunk2 springs, eibach pro, or skunk2, eibach coilovers. Any opinions? Thanks in advance. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 9, 2002
2cute's Avatar
2cute is an unknown quantity at this point
Yes with that much of a drop you will need a rear camber kit and WHENEVER you do a drop you need to get an alignment. Allow the springs to settle before you do (so wait about a week). The way the McPhearson struts are designed they will not camber. When they do the alignment they will tell you if your camber, caster and toe are out so then you can go from there.
Old May 9, 2002
VNlilMAN's Avatar
The Standard One
if your going to go that low i dont think springs are going to cut it... your best bet is coilovers. and you should also get some new shocks. the only ones out are konis.
ground control=$300, konis=$550, installation=atleast 100 this comes out to about 1000
i would just go with true coilovers. they have both shock and coilover together. this is better because they're tuned to work together. also installation should be easy(if the coilovers come with upper pillow mount that is) so you can diy. the cheapest coilovers i've seen are 850. i'm sure you could find a couple for 1000.
Old May 9, 2002
Vatch's Avatar
Vatch is an unknown quantity at this point
<< with that much of a drop you will need a rear camber kit >>
What do you exactly mean by a camber kit?
Only Cam bolts ( like 100$) or the tabs and everything (500$) ?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 9, 2002
VNlilMAN's Avatar
The Standard One
the front uses bolts but the back uses something else. not exactly sure what its called but it replaces the factory one. i think its called th control arm....
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
