Oil on plugs need help
Old Nov 12, 2010
fewall11b's Avatar
fewall11b will become famous soon enough
Notice my car was smoking a little. Nothing bad. It's spraying fuel or oil all cars behind me when I give it some good gas. Went to change my plugs during some tune-up I was doing, and my spark plugs are dripping with oil. Any help on what this may be from? Bad rings or valve seal?
Old Nov 12, 2010
02_d17a1_dx's Avatar
02_d17a1_dx is an unknown quantity at this point
Re: Oil on plugs need help
Oil on plugs means bad spark plug tube seals, pick up a valve cover gasket set, replace them all and thatll cure that problem, not sure if it would smoke that bad, but start with fixing that oil leak.
Old Nov 13, 2010
Kennykid2002's Avatar
Kenny the Ricer
If you open it, might as well replace the O rings while you're at it
Old Nov 13, 2010
fewall11b's Avatar
Thanks I was thinking the same thing.
Old Nov 13, 2010
Mad Dog Tannen's Avatar
Could be bad rings or a bad valve seal. What year is your civic? Are all of the plugs covered in oil or just one or two?
Old Nov 13, 2010
whooops, missed the part where you pulled the plugs out and they were dripping oil, i thought you meant on the coil side, sorry. But yeah, either valve stem seals and guides or rings, check your compression. If its low, its the rings, if not, the valve seals.
Old Nov 15, 2010
MartinL's Avatar
MartinL will become famous soon enoughMartinL will become famous soon enough
I just changed my plugs today and all were covered in oil. It is a 91 civic with 500xxx. Thought this was normal so I went about turning on my car till the entire garage was smoke filled. Oops.
RIPSAW
Nov 6, 2015 04:36 AM
tock172
Jul 21, 2015 06:25 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
silverdevil
20
Jun 2, 2007 04:42 PM
JoeB16
61
Oct 16, 2003 07:58 PM
