HELP: check engine light came on!
Old Apr 22, 2002
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
check engine light came on this morning!!! car still runs great no studders or anything, any one have any ideas on what it could be?
Old Apr 22, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
could be something as dumb as just the light got a glitch and went on, I would get it checked out just in case. You could drive it fine for a while, but later find out that you've been ruining the engine. not worth it, spend some money and get it looked at. The nos could have messed something up, if you use it too much your engine will start to go to hell, this could be the start of something really bad.
Old Apr 22, 2002
BIGLIMPDOG's Avatar
thats what im afraid of and i only have about 270 miles of factory warranty left!
Old Apr 22, 2002
avenger's Avatar
avenger is an unknown quantity at this point
open the gas tank and twist the cap a few more clicks
Old Apr 22, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Might want to look at getting the extended warrenty man. Just to be safe.
Old Apr 22, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
Isn't your warranty voided from the port and polish?? I'm not sure, but wouldn't the nx wet 50 shot also void the warranty....
Old Apr 22, 2002
BIGLIMPDOG's Avatar
yes my warranty is acctully gone but i have a friend at the dealership close to my house that takes care of me! but he cant do anything with my computer or anything major so what i need is im trying to figue out the problem so i know if i need to take my performance parts of and get it fixed or if i can do it my self. Please if u know how to read the computer in our cars HELP ME!!!
Old Apr 22, 2002
Redsands's Avatar
Redsands is an unknown quantity at this point
I'll bet my money that the problem is a two way valve in your fuel system. Happened to me and a lot of others, I had to wait about 2 months for the part because it was back ordered so bad. Just take it in though and get them to hook up the comp.
Redsands
Old Apr 23, 2002
Gen7Civ's Avatar
Gen7Civ is an unknown quantity at this point
Check vac. hoses around the intake...had my ck engine come on a couple weeks ago because the intake heat helped wear a tiny hole in the hose that runs underneath it. I cut a longer piece of silicon hose to replace it with to avoid that stupid kind of prob. in the future.
Old Apr 24, 2002
2k1HXVTEC's Avatar
THE CHOSEN ONE
2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted
i would drive it for a few cycles and see if it turns off. My civic tends to do this if kept at high rpms (close to redline) for extended periods. This is more common on my car because of the higher revving nature of the cvt tranny but im sure with your equipment you experience this as well. also, i have heard from a few people with aftermarket intakes that their light comes on and goes off occasionally. Keep in mind that the light monitors not only engine problems but mostly emmissions control problems (intake,exhaust,cat,fuel/air ratio)
hope this helps!
Old Apr 24, 2002
Trebmalsss2001's Avatar
Trebmalsss2001 is an unknown quantity at this point
Does it stay on all the way while driving or does it turn off after a few minutes?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
