Timing Belts, tensioners, water pump DIY?
Old Sep 28, 2010
xgtcivicturbo's Avatar
xgtcivicturbo is an unknown quantity at this point
Question Timing Belts, tensioners, water pump DIY?
hello! I have a 7th gen sedan and my vehicle needs service of replacing Timing Belts, tensioners, water pump. Im wondering have anyones done replacing their Timing Belts, tensioners, water pump by themself without bring it to shop? I know the product is cheap but the labor is taxing. I needs help, if i about to do it myself what kind of tools do i need to line up the timing belt right position? step by steps direction be greatly appreciated!
Old Sep 28, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Re: Timing Belts, tensioners, water pump DIY?
https://www.civicforums.com/forums/3...ml#post4271119 Everything you need and how to do it.
Old Sep 28, 2010
04 Honda Civic's Avatar
If you havent worked much on cars before you should let the shop do it, however if you are relatively familiar with your motor it shouldnt be too bad.
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CivicVoz
Apr 16, 2015 08:07 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
