Car won't start...battery ok, starts with boost
Old Aug 18, 2010
vinicello's Avatar
vinicello is an unknown quantity at this point
Hi all, I just found this forum and think it's pretty awesome this is here.
Unfortunately, I found it due to car problems, but what matters is I found this site. Hoping you could help out.
I have a 2006 Civic DX
I was unable to start my car the other day...got a boost and all seemed ok. I stopped for a coffee and again it would not start. I was able to get a boost again and managed to drive it home (150 kms). I had to turn off the ac as it seemed to be causing some issues (red light came on periodically) and my radio was not working either (asking for code). I have not been able to get to my car until today and still it wouldn't turn over. I removed the leads on the battery and cleaned the posts...still nothing.
I now started noticing a green key light come on and figured it was due to the radio code. I thought this may have caused the car to keep me from starting it. I entered the code, crossed my fingers and turned it over....nothing. all lights are coming on but the car won't turn over.
I tried a couple of times and it started asking for the code again.
Unsure what might be the problem. it will start with a boost but not otherwise...battery tests as ok.
Any ideas? suggestions- before I take it in?
your help is greatly appreciated.
Old Aug 18, 2010
vinicello's Avatar
Re: Car won't start...battery ok, starts with boost
sorry, incorrect thread. will post elsewhere.
Old Aug 18, 2010
MindBomber's Avatar
Live for the Twisties
The radio code is triggered by the battery dying, thats definitely not whats preventing the car from starting. You mentioned a red light coming on, what red light specifically? My first guess would be the alternators not charging the battery.
Old Aug 18, 2010
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
thats my guess either ur alternator is bad or the battery. when the car is running connect a volt meter to it and u should get 14.2 volts anything less ur alternator is bad
Old Aug 18, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
Frankly I don't take too much stock on your assertion "batt tests OK" when u can't even say what red light came on. All points to a weak batt at this time.
Old Aug 18, 2010
02civicsi02's Avatar
Low and slow!
The green key light that comes on is your immobilizer. It always comes on for a little when you first turn the key to on but then goes off if it does not go of and keeps blinking the the ignition is not recognizing your key. If it just stays on constant with no blinks then you will have to get the immobilizer turned off and that deals with your ecu which you will have to go to honda and have them reprogram it. If the immobilizer is blinking or stays on most the time the car will not start cause it is a theft warning kinda sort of.
But if the car will not crank but will from a jump then its either the battery or the alternator.
Old Aug 19, 2010
gangulyarchan's Avatar
gangulyarchan is an unknown quantity at this point
Almost similar thing happened with my friend's civic. His power windows, wipers and radio would turn on but car wouldn't start.
If the alternator goes you will be stuck in the middle of nowhere, everything will die all at once. Nothing will work not even your lights. Also the car needs maximum cold cranking amps when you start.
You need a new battery, period.
Old Aug 25, 2010
Caymanized's Avatar
Caymanized is an unknown quantity at this point
I agree with the majority of the opinions. Check your battery first and foremost with the car running. If that checks out, then move to the Alt. If that too checks out, I would suggest checking all the fuses, all the relays, and all the ground points.
Hope I could be of any substantial help! Good luck tracing the problem!
Oh and pics and/or vid would be of a great help for us to properly diagnose the problem.
CarStuff
Dec 6, 2020 12:52 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
