Did I flood my engine?
Old Mar 22, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
I was fixing my throttle cable and I pressed on the gas several times to see how it felt. Afterward the car drove very slow. I smelled the oil which only has 800 miles on it, and it smelled heavily like fuel. The car drove great before I did this. I got the impression that on a fuel injected vehicle, pressing on the gas does nothing while engine is off.
Old Mar 22, 2010
Re: Did I flood my engine?
I was having power/fuel in oil symptoms before this though. I wonder if it's the fuel pressure regulator (too rich, too lean) because while driving, I get this surge of power, then it goes away, then comes back all randomly. I gotta check my fuel pressure...
Old Mar 22, 2010
pressing the gas pedal only opens the throttle plate when car is off. ive pressed mine over and over and nothing happened. there is no way gas should be coming out.
Old Mar 22, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
yea, you definately did not flood your engine with gas. the fuel injectors run off electricity and with the car off, theres not current flow, ie no fuel being injected.
Old Mar 22, 2010
I smelled my families vehicles and they all smell the same. I was told that it's called blowby and is normal.
I know, it makes no sense because it's not really the gas pedal but the air pedal.
Old Mar 23, 2010
Alright, false alarm. Tested my fuel system and got normal readings. Turns out my throttle cable was being overly pinched meaning that I couldn't add proper slack to it, therefore I had to press the throttle really low for power. I unpinched it at the firewall so it's more free-moving, readjusted slack, and now it's all normal.
Old Mar 23, 2010
04 Honda Civic's Avatar
Yea, you cant flood a fuel injected car when it is off.
Old Mar 29, 2010
What about when the engine is off but you're in position II (on) and pressing on the gas?
Old Mar 30, 2010
Nobody knows??
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
bluecoupe
Jan 23, 2002 05:50 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
