Power steering fluid.
Old Jan 18, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Does it ever need to be changed?
Old Jan 18, 2010
Re: Power steering fluid.
yeah when it starts to get darker. i just drain and refill the reservoir when i notice it not looking as clear as the new stuff. i think ive changed it a few times so far and just recently too. thats the easiest way without doing a full flush and most fluid circulates around anyway. and use only the honda fluid. it helps steering response to have newer fluid in there.
Old Jan 18, 2010
CraigW's Avatar
Shine a bright light through the side of the reservoir. It should be the color of honey if clean.
Old Jan 18, 2010
Mine is dark. I need a change. So ummm, what do you mean by drain? Undo the hose or tilt the resovoir upside down?
Old Jan 18, 2010
Okay, I should have checked my honda book. It says:
Raise the reservoir, then disconnect the return hose
Connect a hose of suitable diameter to the discon-
nected return hose, and put the hose end in a suit-
able container.
CAUTION: Taks car. not to spill tho lluid on tho
body and parts. Wipe off any spilled fluid at once.
Start the engine, let it run at idle, and turn the steer-
ing wheel from lock-to-lock several tim€s. When
fluid stops running out of the hose, shut off the
engine. Discard the fluid.
Reinstall the return hose on the reservoir.
Fill the reservoir to the upper level line.
Start the engine and run it at fast idle, then turn the
steering from lock-to-lock several times to bleed air
from the system.
Recheck the fluid level and add some if necessary.
CAUTION: Do not fill the reservoir beyond the
upper level line.
Old Jan 18, 2010
do you really want to do that tho? you can just remove the side hose, drain the reservoir into a cup, then reconnect the hose and pour new fluid. drive around once, then top off the fluid to max again once the air goes out. after a couple weeks check the fluid color. if its still darkish, drain and refill again. ive never had to do it more than once tho.
Old Jan 18, 2010
RonJ's Avatar
RonJ will become famous soon enough
I think the method described in the service manual is best because you eliminate as much old fluid as possible, thereby reducing the amount that the new fluid is diluted by old fluid. Also use Honda or Honda-recommended power steering fluid. It's important to replace the fluid regularly to avoid destroying the seals in the steering rack, which is a bear to replace.
Old Jan 18, 2010
lowlife9's Avatar
i just used a turkey baster.
Old Jan 18, 2010
Gearbox, I think your method is the same, only difference being that you didn't turn the engine on and turn the wheel during removal of the old.
That's lame how it doesn't even mention PS fluid in the maintenance schedule. Any way, I had to buy like 4 of those bottles for honda (12oz each). 15 dollars total.
Old Jan 18, 2010
cb450sc's Avatar
cb450sc is an unknown quantity at this point
I use the turkey baster method as well. I change it out three times over a week. It seems to get most of it out that way. I do that once a year.
Old Jan 18, 2010
You need a turkey baster no matter what since fluid will spill out once you disconnect the hose. I did the full flush and it's 2 not 4 of those 12oz bottles, the guy was wrong. Well, now my PS pump makes a gas-powered-saw sound with the steering wheel turned. Maybe it did that before the change, should I be worried?
Old Jan 18, 2010
RonJ's Avatar
You need to bleed the system. With the front end on stands and the engine idling, turn the wheel from lock to lock multiple times and then top off fluid in the reservoir.
Old Jan 18, 2010
I already did all that. I followed the instructions perfectly. Will air still bleed driving around with the cap on the reservoir?
Old Jan 18, 2010
RonJ's Avatar
I would continue to turn lock to lock with the engine idling until the sound subsides. This is best done with the front end on stands.
Old Jan 18, 2010
even if you just drain and fill, you need to drive the car afterwards and make full point turns in both directions to let the fluid circulate. when you get back and let the car cool, you will prolly have the fluid down to MIN level and need to add more. im always nervous of running the PS without fluid using hondas method so i stick with drain and fill and the rack still has fluid. the system will bleed itself of air as you drive, but i hope your noises go away. usually those are made when the rack is low on fluid.
Old Jan 18, 2010
I will do what you say and see if it goes away. Man when I was turning the wheel during idle, the pressure was so intense that the hose snaked out of the collection container and beads of PSF shot everywhere. I had to bust out my snake charming flute to tame it. Now I know why you do it your way.
Btw, the previous poster said that good fluid should look like honey. Well not true. Mine looked exactly like honey, but the new stuff was much more on the clear side.
Old Jan 18, 2010
lowlife9's Avatar
the way i did was suck out the fluid fil it up then start the car and turn the wheel back and forth then start over till it cleard up i didn't want to run it without fluid like gearbox.
Old Jan 18, 2010
that turkey baster is a great idea too, its a bit difficult to maneuver a cup under the hose and pour most of the reservoir out. and yeah new fluid should be clear color almost like water. the stuff i got few yrs ago had a honey look, but the new stuff i just got was almost colorless.
Old Jan 18, 2010
RonJ's Avatar
You definitely want to secure the return hose in a suitable container so that fluid doesn't spray all over. Having a buddy's help would also make the procedure easier. Nonetheless, this is the best method because you eliminate the maximal amount of old fluid, which is the ultimate goal.
Old Jan 21, 2010
Works good now, thanks for all the help.
RIPSAW
Nov 6, 2015 04:36 AM
hans.pcguy
Jul 12, 2015 12:19 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
cgavin1
Jul 7, 2015 07:10 AM
bsmiley
Apr 27, 2015 01:27 PM
