another spark plug thread
Old Dec 31, 2009
laack's Avatar
laack is an unknown quantity at this point
my damn toe thumbs dropped one of my plugs and bent and scratched the hell out of the terminal.i tried soften the blow with my foot but instead stomped on it.
car came with some autolite plugs...
replacement: denso seems to be the plug of choice on here but at $40 i would need to be able to justify buying them.
denso (8.99) or ngk gpower single platinum (2.99). would i see a noticeable difference in MPG? I would rather see an increase in efficiency over power if those are what the trade offs will be.
94 civic dx 1.5
Old Dec 31, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: another spark plug thread
I don't even run platinum at 134k miles. I get 40mpg average highway, and 34 minimum city during the summer. I just use the standard non-plat NGK's. I don't have experience with the fancier plugs to be honest.
Old Dec 31, 2009
BlueEM2's Avatar
Whachya lookin at?
NGK Iridiums are the best. But any brand of NGKs are good. Denso as well. Those are the ones that seem to be the most popular here. Just like you say. If you don't want to spend that much. Get the NGKs.
Old Dec 31, 2009
Stay away from Bosch, they will cause problems in hondas. Next time I replace plugs I will try ngk platinums. Why do they say that after 90k miles platinums should be run?
Old Dec 31, 2009
if youre poor, get ngk v-power copper plugs for $2 each. if youre rich, get denso iridium for $10 each. both will have the same performance and last a couple yrs. the denso will use a bit less electrical energy so your alternator wont work as hard.
Old Jan 1, 2010
04 Honda Civic's Avatar
Go with V-powers like gearbox said..how the **** are Denso so expensive in your area? I believe they are fairly cheap here.. at least the OEM kind, not them special 4 prong *****.
Old Jan 1, 2010
laack's Avatar
I went with the ngk platinum plugs 2.79 a piece vs 1.99 for the cheapest copper ones. I've never heard go platinum after 90k.
What is the difference between these and the expensive ones? denso = lower load on alternator.. any other benefit? platinum laser for 10? what is the advantage between that one and the normal platinum
Old Jan 1, 2010
laack's Avatar
gap- manual says .043. spark plug ngk- zfr5fgp is gaped at .038.. i know i cant regap these. did i end up with wrong plugs?
Old Jan 1, 2010
0.044 should be stock gap and usually ngk sets the gap. did you measure it? sometimes its correct when you use the gapping tool. check sparkplugs.com for the correct part numbers.
Old Jan 1, 2010
laack's Avatar
Part number matched up but the platinums gaps were off.(autozone measured a 2nd set that were also off). I used 2 different gapping tools, 1 round one and the other was my feeler gauges. I ended up returning those plugs for copper v power plugs. gapped and installed.
Old Jan 1, 2010
the v-power is really better than platinum for performance. platinum just lasts longer but doesnt conduct as well. the coppers should last you 2-3 yrs, but for how cheap they are its worth changing every year. i keep my denso iridiums for 3 yrs, per denso recommendation.
Old Jan 2, 2010
since the platinums don't conduct as well, I bet the .038 gap is proper spec.
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
