alternator removal
Old Dec 18, 2009
laack's Avatar
laack is an unknown quantity at this point
alternator removal
94 civic dx 1.5
The lower bolt is stuck.. i cant get the alternator to move. the bolt on top is removed, connections off. cant budge the alternator. the nut is off, but the long bolt on the bottom will not budge.
any ideas?
Old Dec 18, 2009
Re: alternator removal
have you tried penetrating spray or pb blaster? can try a longer socket wrench for more leverage, but dont break off the bolt if its stuck. its prolly rusted in there.
Old Dec 18, 2009
laack's Avatar
I'll give it a good soaking tomorrow. I gave up for the night. The bolt doesn't have a head on it, just a square end to prevent it from turning when the nut is turned.
so far... i put the nut back on and threaded it to the end of the bolt to prevent damage to threads... hammered as best i could with the limited space.. put a block of wood against it and kicked at it... swore at it and now i'm leaving it alone.
tomorrow will be a fun filled day of hammering. any other ideas are welcome.
Old Dec 18, 2009
EK9_XCVI's Avatar
EK9_XCVI is an unknown quantity at this point
If you have access to a torch that will do, but be careful with the wires. Mine had to be heated. And now that you have soaked it, a little heating will definately get it done.
Old Dec 19, 2009
laack's Avatar
still stuck.. more heating and hammering to go tomorrow. I unbolted the motor mounts and lowered it a bit on the jack so that i could hit the bolt head on.
more ideas are welcome. I'm getting desperate and thinking about having it towed to a shop to have it done.
Old Dec 19, 2009
try a breaker bar (or put a pipe extension on a socket wrench) for more leverage. as a last resort, you may have to use dremel and cut it loose, then deal with getting the rest out once the alternator is off.
Old Dec 20, 2009
laack's Avatar
still no luck. I had the nut off a couple days ago, but i cant pound the bolt through, or budge it. the head of the bolt doesnt have a hex head or anything to secure a socket to, just a flat square end to keep the bolt from turning when tightening the nut.
i think i need a bigger hammer and a stronger arm
Update:
I got the bolt flush with the mount, but no further. I'm throwing in the towel. I'm going to find a shop that is willing to cut it out...
Old Dec 21, 2009
laack's Avatar
I had a local shop remove it. It took 30 minutes with an air hammer to beat it into submission. the bolt is in really corroded and mangled from removal. What is the best replacement bolt material that will resist corrosion and seizing to the sleeve in the new alternator?
random question: I drove to the shop on battery power with the alternator disconnected and the belt cut off. Why didn't my battery light on my instrument panel turn on? I would have assumed that driving on battery alone would trigger the batt light. It usually kicks on at low rpm with the bad alternator so i know its not burnt out.
Old Dec 21, 2009
hmm maybe alternator wasnt plugged into the harness so the ecu had no way of knowing that less power was being produced. try and get the hi grade bolts they have at the hardware store and use anti-sieze grease on it.
Dani1993
Jul 24, 2015 09:02 AM
jzhartman
22
Jul 23, 2015 10:42 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
ballmich
Jul 9, 2015 11:59 AM
