'01 MCU replacement help
Old Aug 29, 2009
01EXSedan's Avatar
01EXSedan is an unknown quantity at this point
Hey all.
My '01 EX sedan is suffering from the dreaded failed MCU (i.e no remote open, no power doors, brake light on, no AC...etc.) and I just received my new unit from Majestic.
Is this a DIY project that someone with limited electrical background (me ) can undertake? If so, are there any "how to" articles or videos out there that anyone knows of? My Haynes manual unfortunately does not have this job listed.
Any help is greatly appreciated!!!
Old Aug 29, 2009
CraigW's Avatar
Re: '01 MCU replacement help
I cannot say 100% for certain but... I think that the multiplex/fusebox unit change consist of all connectors and plugs and should be simple. I would take detail pictures and make a drawing detailing any open connectors. get good documentation before removing the plugs.
Of course unhook the battery before starting.
I will take a look in the manual.
Old Aug 29, 2009
speedfoos's Avatar
**** the manual. Are you talking about the engine fuse box or the ECU? Either way, the plugs are shaped so they only go in their appropriate slot - it's pretty simple. However, if it's the ECU that you are replacing, your car will not start after you replace it because of the immobilizer. The key, the ECU, and the ignition cylinder all have to match in order for the car to start. If one of the three is different, it won't start. Remove and replace the ECU so you know how to do it, drive to the dealership with the old ECU installed and tell the techs what you are doing. They will flash your key so that everything matches and you can install the new ECu right there in their bay before they do it.
If it's the engine fuse box, again, you're looking at a 10-minute job at most. The two white +12V cables unbolt, then remove the box, flip it over, remove the wire cover, grab your new unit, and just start doing a one-for-one exchange from old unit to new unit. It's pretty easy.
Old Aug 30, 2009
CraigW's Avatar
My guess is they are talking about the under dash box and the multiplex unit.
Old Aug 30, 2009
01EXSedan's Avatar
Indeed I am.
Looking at the new unit it does look as if each connector opening is different so that should absolutely help when resassembling.
Two questions I can think of:
1) Is the bolt on the bottom right hand side all that holds the unit in place? It looks as if the MCU sits on a track and slides out once that bolt is removed.
2) Is there enough slack in the wire looms to remove the MCU with all the connectors still attached or do you have to unhook them before removing it?
Thanks again all!!
Old Aug 30, 2009
CraigW's Avatar
Here is the factory info, There will be some extra wire for the access movement but not much extra.
hth
File Type: pdf
Old Aug 30, 2009
01EXSedan's Avatar
CraigW THANK YOU THANK YOU THANK YOU!!!!! That is just the info I was looking for!!!
Old Aug 30, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
hth
Good info! I might need that someday
Old Aug 30, 2009
CraigW's Avatar
Would you be interested in sending me your old junk fusebox ??? Have always wanted to tear one apart. I would gladly send you the money to cover shipping. Let me know.
thesushiboy
Apr 12, 2015 02:54 AM
2k2civicballer
25
Feb 7, 2002 12:22 PM
sivic2k1
Jan 31, 2002 12:30 PM
Jeeves
Jan 20, 2002 10:38 PM
my2k1vic
Nov 29, 2001 10:29 PM
