Look at this pic, Should I change the crankshaft?
^Warranty voider
Re: Look at this pic, Should I change the crankshaft?
wtf am i looking at? can you be a little bit more descriptive? like from where you shot this picture and what you are pointing at?
It is where the harmonic balancer goes, you know where the crankshaft pulley is inserted to.
The bolt its a little bit tough to tread in and tread out...
so the pin will work just fine, right?
It should be fine. Just hit the crank pulley bolt with a little WD40 before you put it back in this next time.
PB blaster / THRUST > WD40. make sure there is no play in it (thats if you have the motor apart.)
but yeah, as stated, re-thread it.
does it make noise when driven? under any circumstances?
^Warranty voider
oh you took a picture of the reflection on a mirror. I gotcha now. Only time i thought you'd need to replace teh crank is if you weld the rod bearings to the crank.... yes it is possible if you beat the **** out of your engine enough.
Wild Cranker
427
Jan 28, 2016 06:49 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
159
Jul 5, 2015 09:54 PM
stryder12
Jun 30, 2015 08:33 PM
