Sea Foam
#33
Re: Sea Foam
If you use sea foam,I suggest you change your oil afterwards.
If you have been driving around with a bad o2 sensor and been running rich for a while,its not smart .
For the most part,on a high mile engine thats been ignored,it would be the equivelent of throwing a handfull of wet dirt into your cylinders and scratching the **** out of them!
So it IS A GAMBLE IN SOME CASES,Ive seen cars start knocking and tapping bad after a foaming.
What is it really going to do for you that is good possibly?
Clean the carbon off your pistons,clean your 02 sensors but some will foul ur 02,get all that carbon off your valves so they close good n stop ticking ,
clean ur throttle body.
My opinion,look into the intake track and see if theres dirt.look in your oil cap and see if theres bad sludge.if it looks ok,then you should be safe for a foaming
jiggerachi
02-06-2003 10:18 AM
