Head Unit Relocation
Old Apr 9, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
Can someone tell me how they moved their stereo to the lower part of the dash and what you had to do to make it right
Old Apr 10, 2002
inca's Avatar
inca is an unknown quantity at this point
Good luck..nobody helped me when I asked that a while ago [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Apr 10, 2002
WhiteRabbit's Avatar
http://www.calpoly.edu/~sciccare/my%20install/deck.jpg
a piece of 1/4 inch plywood, a coping saw, sandpaper, and two weeks of my life.
later filler, paint, resin, fibercarbon, and i still need to polish it. its a whole new animal now ^.^
Old Apr 10, 2002
i know its not what you wanted, but some info is better than none =/
Old Apr 12, 2002
kano8016's Avatar
kano8016 is an unknown quantity at this point
first you'll need to extend all the wires, then find something to fill the void, then get creative with the install. different people do it different ways!
Old Apr 12, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
DIY recation of HU
Old Apr 12, 2002
1slo2k1civic's Avatar
1slo2k1civic is an unknown quantity at this point
I f you are going to put in a aftermarket radio if you use the wiring harness it will drop down with no problem.
Old Apr 12, 2002
Spider883's Avatar
9K Redline Owns U
1slo2k1civic the wireing harness will drop down without a problem. it has alot of slack in it.
Old Apr 13, 2002
ciViLiciOuS's Avatar
ciViLiciOuS is an unknown quantity at this point
WhiteRabbit,
where'd you get the carbon fiber layer to cover the top piece?? i mounted my EQ in the same spot you have your deck, and i need something to cover the plain black panel.
Old Apr 13, 2002
TAP plastics, if there isnt one near you, www.TAPPlastics.com, i believe.
its the same stuff i used on my trunk, and also that i will use on my fiberglass hood, and what i WOULD use if i were to make a fibercarbon hood conversion (ppl here care more about weight than looks tho) great stuff, i couple it with teh marine grade epoxy, then finish the whole thing off with a UV protectant varnish (what a pain) shines like no other tho (i need to update that pic, i filled in teh weave now.)
edp22
Jan 27, 2002 02:51 PM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
