Batt light/no start
Old Jan 22, 2009
gregscott's Avatar
gregscott is an unknown quantity at this point
Batt light/no start
I have a 2k3 manual trans and the battery light will come occasionally but go out as rpm increases, then out of no where it won't start. It has about 43k miles. I have checked battery, alternator, but not starter. All checks ok, this not a regular problem but a PITA. Anyone else with this?
Thanks Greg
Old Jan 22, 2009
greeen01civic4d's Avatar
Re: Batt light/no start
check your grounds, thats the most likely case
Old Jan 23, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
even if the car wasnt grounded well it would not trip the battery light i dont think. i think its the alt. check the engine grounds as well though. alternators can be a PITA sometimes because sometimes they charge and sometimes they dont.
this is prob a longshot but, do you have a modded downpipe with the o2 sensors moved? i had the same problem as you and it turned out a grounded out o2 sensor wire was causing me my problems somehow, i really dont know why... but when i fixed the o2 sensor all my problems went away.
Old Jan 23, 2009
Jdm01Em2's Avatar
Jdm01Em2 will become famous soon enoughJdm01Em2 will become famous soon enough
a battery light usally means alt. promblem 80% of the time if its not the alt its a short some where good luck
Old Jan 24, 2009
WannaBFast's Avatar
Prowlin' with a Purpose
cause the alternator runs on the same fuse as the primary o2 sensor
the charging could mean a number of things, could be a burned out fuse, but that would turn teh CEL on.. otherwise the voltage regulator in the alternator is going bad, or the ELD is going bad, the ELD is probablly the easiest, quickest thing to swap out, but it probablly is the alternator
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
