installing a spoiler need help ASAP
Old Apr 30, 2007
seelsy's Avatar
seelsy is an unknown quantity at this point
hey, ok ive got the spoiler mounted, now what do i do with the led wires for the light, i know im supposed to hook into the third break light, but where is it and how do i hook it up for the led, i have a little red connector that im supposed to put the two wires in, but what two wires, i need help, pictures would be really helpful if anyone has some, asap!!!
Old Apr 30, 2007
cato1978's Avatar
cato1978 is an unknown quantity at this point
Re: installing a spoiler need help ASAP
the third brake light should be in your rear window...
I know that's not much help, I don't mess with wiring enough to feel confident telling you much more.....
Good Luck man....
Old Apr 30, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
what does the connector look like??
Old Apr 30, 2007
LT2004ever's Avatar
http://www.handa-accessories.com/civic/02CIVWING.pdf
oh well this should be more than enough info
Old Apr 30, 2007
seelsy's Avatar
it's very detailed but that wing has wire terminals, mine just has a red and a black wire, am i supposed to cut the wires of the third break light or what?
Old Apr 30, 2007
cato1978's Avatar
Damn, LT, you on your game right now or what? Good find.
Old Apr 30, 2007
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
tap em. find out which is positive and which is negative.
Old Apr 30, 2007
LT2004ever's Avatar
Yea what he said..
but also do u by any chance have a pic of these 2 wires? like are they the wires that connect to your wing and come out of one of the sides? like is it the spoiler harness??
Old May 1, 2007
CraigW's Avatar
You remove the original 3rd bulb/socket assembly (twist left to remove)
Once the socket is out remove the connector from the socket (pulls out end)
The 2 connectors you have available now can be coupled easily with the red coupler you mentioned.
Old May 1, 2007
seelsy's Avatar
so do i need to cut off the end of the third break light the expose the two wires , the part that connects to the actual light assembly, or do i take the assembly out alll together
Old May 1, 2007
Kevbotron's Avatar
I like my commute
you should be able to just unplug it w/o having to cut the wires.. much like all the other brake lights
Old May 1, 2007
seelsy's Avatar
no i can unplug it, but to hook up the spoiler light, do i need to cut the wires so i can hook them with the spoiler wires
Old May 1, 2007
CraigW's Avatar
No, they both have their own plugs. The 2 plugs are coupled with the red coupler supplied.
Old May 1, 2007
DsevenEm2's Avatar
This is Myspace
lol i had the same issue...but it was way easier than u think....look under ur trunk or w.e and just look underneath the rear window brake light thing....ull see sum wires and a socket looking thing just pull it, turn it..w.e and itll fall out.....now look into the back of the socket or w.e its called for two wires going into it...thats ur positive and negative...put in one ur - and + and have sum1 step on the brake to see if ur light comes on..if it doesnt then swithc em around...now wat u want to do is stuff ur cables into this one as deep as they can go (shut up) and zip tie all 4 wires together..or tape them..yes its very jerry rigericious.....but it does work...mine hasnt come loose n works perfect.
Old May 1, 2007
LT2004ever's Avatar
... the installation pdf sez that seelsy
read steps 15-19 and see if that solves your prob
Old May 3, 2007
seelsy's Avatar
yea LT it does but the only problem is the spoiler doesnt have a harness that hooks into the original brake light cable, it just has a red wire and a black wire, no harness to connect to the factory cable harness.
Old May 3, 2007
Kevbotron's Avatar
I like my commute
LOL I see now It sounds like you will need to cut the wires.. but save the harness in case you need to go back to stock... and like thefever said, tap em' to see which is pos and neg.
Old May 3, 2007
LT2004ever's Avatar
OHHHH!!!!!!! ok yea now i got ya, just like kevbotron my bad
Old May 3, 2007
DsevenEm2's Avatar
This is Myspace
um..ok..im useless lol
Old May 3, 2007
seelsy's Avatar
lol no worries, i got it working, thanx for everyones help though
Old May 4, 2007
cool. you disconnected your old brake light right?
Old May 8, 2007
seelsy's Avatar
yea, wired the led light on the spoiler into the lines running to the third brake light, works perfectly now. was just a little reluctant to cut any wires as im not too big into wiring so i didnt want to mess up anything electrically in my car and either void my warranty or mess the car up completely.
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
