need help. again.
Old Mar 18, 2007
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
need help. again.
So, the Honda has given me nothing but problems lately. I was on my way back from Houston today and my car stalled out. Just started jumping and everything electrical shut off. I still had steering and brakes though. I pulled over and realized a ground wire had been torn out of it's ground. I did some shitty mechanical work on the highway and shoved the ground wire(which was the one from the frame to the tranny) in between the screw. It started right back up.
I got home and was fixing the ground, and my radio came on. No keys or anything, so I was like... well that's odd. Anyways, I went to go start my car, now the bitch won't start at all. It won't turn over or anything. The electrical stuff comes on and all the indicator lights come on, but when I turn the key... nothing. I had this same problem like 2 months ago, and it was the ground. Now I know it's not the ground... so what the hell could it be? I need help pretty fast.
Old Mar 18, 2007
sl33pyriceboi's Avatar
check all ur fuses and relays....mabee u burnt one out?
Old Mar 18, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
if all the fuses and relays are good, have the battery tested. if the battery is good, it could be the switch. the electrical part, not the cylinder.
Old Mar 18, 2007
thefever's Avatar
I need a drop
fuses and relays have all been checked.
unclejuice, which switch are you referring to?
Old Mar 18, 2007
uh, the switch. its part of the ignition switch. its not the key cylinder you think about when you think ignition switch though. theres a little module that goes with it. when they go bad, **** goes wicked crazy. it connects to the cylinder part of the ignition switch. when you turn the key, it turns inside the module to make contact to the car starts and all the electronics come on. theyre usually 50-60 bucks.
Old Mar 18, 2007
thefever's Avatar
I need a drop
would this be a gradual problem, or could it have just like... broke?
Old Mar 18, 2007
it could be a gradual problem. i just replaced one for my grandmother. sometimes the car would start and sometimes it wouldnt. depends if its making contact inside the switch or not.
Old Mar 18, 2007
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Hmmmm... If your radio just kicked in without being in accessory or power mode, it sounds as though you've got some crossed wires somewhere. I'd check to make sure that nothing else got pulled or ripped when your mishap occured. In relation to your radio, it sounds like your accessory power went hot and became a constant. You may want to start there.
runawaykinms
15
Mar 22, 2019 10:32 AM
robjcivic
Mar 12, 2017 12:10 PM
Stock 99
Sep 5, 2015 06:06 AM
msaeger
Sep 2, 2015 08:47 AM
Blazz
Aug 30, 2015 11:07 PM
