boiling coolant... COME IN.
Old Mar 7, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
yeah my coolant is boiling.. i replaced the thermostat, the radiator cap, headgasket and flushed the system. i am using prestone 50/50 blend. the car has been doing FINE until last night. the car doesnt over heat during regular driving habits/conditions. it only overheats when i do 1/4 mile boost run. is this a sign of blown head gasket? i hope i dont have to replace it again. this sucks. if this has anything to do with it i lost the overflow reservoir cap and have been driving without it ever since about 2 days ago.
Old Mar 7, 2007
help! . at school and im bored. 23 views and no replies =/
Old Mar 7, 2007
rutscivic's Avatar
rutscivic is an unknown quantity at this point
get honda genuine coolant,you only need one jug, get a reservoir cap, ...flush it with that, make sure the thermostat opens up then go...
Old Mar 7, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
When you changed the gasket did you check and see if the head was flat? If it warped from heat or removal, and its not flat now, you're likely to blow it again. Additionally, its possible you hava an air bubble somewhere, you can try pressure flushing the coolant system, or checking the water pump for leak/siezure. If it overheats in a 1/4 mile, it sounds like you have no water flow.
Old Mar 7, 2007
hkscivic's Avatar
hkscivic is an unknown quantity at this point
bleed your cooling system of all air and make sure the cooling fans are turning on
Old Mar 7, 2007
junior h.m's Avatar
junior h.m is an unknown quantity at this point
^^^wat he said
Old Mar 8, 2007
thanks for pointing out the obvious. lol -_________-... yeah i checked the head with a precision straightedge and it was flat. also, i checked my oil dipstick and its below the lowest dot about a week after an oil change. i dont know if its a whacky reading cuz i checked the oil level about 5-10 minutes after the motor was off but i was like wtf how can i lose that much oil when only a few drops of oil is in my garage. i figured il check the dipstick in the morning. i was thinking shot piston rings? but wouldnt i notice a substantial decrease in performance? i was driving around today and smashed it a little and it felt all the same. need help. thanks in advanced.
Old Mar 8, 2007
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
If you dont notice any major oil leakage, then it could be a multitude of things. Have you checked compression? Its possible that your rings are shot or perhaps bad valve seals. Do you drive it hard constantly?
Old Mar 8, 2007
if you replaced all that you say, and bleed air from the coolant, the only thing left is the water pump.
Old Mar 8, 2007
blouisgod's Avatar
Life Begins > 6800rpms
^ i was thinkin water bump. is your radiator hot after normal driving? just sounds like no fluid is circulating; also let the air out if you havent purged it already.
Old Mar 8, 2007
i let all the air out, didnt replace water pump. anyone got more ideas on the oil thing though? i was thinking a new radiator wont hurt, thought it might be a good mod since im boosted too. the oem honda one sucks imo.. all plastic. i was looking at this ebay one.
http://cgi.ebay.com/ebaymotors/01-05...QQcmdZViewItem
so i guess il change the water pump and maybe the radiator. if it still overheats then what? lol.
Old Mar 8, 2007
Macko's Avatar
Macko is an unknown quantity at this point
check to see the rad fan works
Old Mar 8, 2007
AThompson18's Avatar
AThompson18 is an unknown quantity at this point
I see that your boosted, so when u first changed ur headgasket, did u put in arp head studs. If not you verywell could of blown it again because our cars are notorious for blowing headgaskets on the stock head bolts.
Old Mar 9, 2007
i didnt get the headstuds, i was planning to but i didnt have the money and i needed the car asap. this car is my daily driver. i was running on the other head gasket for about 8 months before i replaced it so i dont see why this one should blow out in a weke or 2
Old Mar 9, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
water pump!!!!
Old Mar 9, 2007
Jap-Euro Fusion
Because the stock headbolts cant be retorqued over and over again. They stretch out of spec.
If the oil is gone, I'd find it. No oil will definitely send up the water temps. Check the compression, etc....
BTW, that radiator looks a bit on the chinsy side, and there's nothing wrong with the stock radiator The fact that its got plastic tanks doesnt really matter.
Old Mar 11, 2007
^^ thanks
i still got the oil, turned out it was innaccurate readings. i let the car sit overnight then checked the oil and its fine. for some reason the car doesnt wanna overheat as much anymore. before when i used to smash it once the coolant would boil, now when i smash it the temp goes up a little then just goes back down to normal operating temp. i didnt even change anything..... wierd
Old Mar 11, 2007
haha.. forgot u live in vegas too.. lol.. u need to get it fixed before summer hits..
Old Mar 11, 2007
yeah i know right. got no ac either. my stupid self removed the ac condensor not really knowing what was going to happen and the freon sprayed everywhere. lol... i might take your tranny later. low on funds still though. i will let you know if i ever make enough spare cash for it.
Old Mar 11, 2007
TRIZ's Avatar
My friend (jap girl with a VW) came over to me today and is like, my car smoked and the coolant was boiling. I was like hmm... let me go check something, and I went straight to this thread.
Doesnt make any sence though because she doesnt have any mods or anything. Its just a VW golf. I think she had the radiator hoes replaced because there were 5 holes in it, and some other stuff that ended up being 500 bucks. Any idea what it might be.. water pump? Do VW's have thoes? I think her pos golf was a 93 or something.
Old Mar 12, 2007
haha.. all cars have some type of water pump.. and some type of oil pump... of course they gotta have something to circulate the fluids... lol
Old Mar 12, 2007
TRIZ's Avatar
Well.. any guesses on what it is, and how much to fix?
Old Mar 12, 2007
well we need some more info triz. telling us it smoked and the coolant was boiling doesnt help much! ooooo i got my new tires in the mail today... so excited. the bfgoodrich kdw2s cant wait!
Old Mar 12, 2007
TRIZ's Avatar
yeah dude, I dont know much more then that. I took a quick look at it and the dipstick didnt lock shut, the plastic part was broken off, so the dipstick kinda just sat there ontop of the snapped part. There was some oil that was around that area lower down on the engine. It basically over heats, smoked, she popped the hood, and the coolant was boiling. Her gauges are out, so she cant tell the temp of the engine when driving, until it starts smoking.. man, vw's suck- I told her to sell it and get a honda, but shes still realizing sunk costs... *shakes head* I guess shes heading over to a shop to check it out today. I guess no1 has any answers. Your problem seems to have just fixed its self right? I doubt a VW would fix itself. We'll see what happens though. I'll let u know what her problem(s) was/are.
Congrats on the tires. I'd benifit from some new rubbers but the ones I have arent even halfway gone... Enjoy thoes.
nirvanaguy
25
Oct 26, 2017 07:26 PM
ricer_em2
May 11, 2016 08:09 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Bruce2
Sep 21, 2015 08:01 PM
Bikergofast
Sep 12, 2015 10:54 AM
