any available diy`s on rsx seats
Old Jan 13, 2007
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
just purchased 05 type s seats and cant seem to find any working diy for the install.. Can anybody help me out with this.. I know there was a sticky for
www.hondawerx.com/RSXseats.htm but the link doesnt work.. can anybody help me out with this thanks
Old Jan 13, 2007
sl33pyriceboi's Avatar
there are 4 bolts on the base...unbolt them.....i think its a 14mm or 13mm....forgot....
then unplug the seatbelt plugs
then take off ur old seat.... then put in ur new one....... plug the seatbelt wires back in.....bolt the 4 bolts back on...and ur done
its a direct replacement....i dont know WHY u need a DIY
Old Jan 13, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
just had mine too! direct swap bro, i mean not super direct, gonna work on the last bolt and you definitely need man power, the only thing you gonna need for a DIY is on SRS plug cause i havent figure out my problem yet which i think its the passenger airbig since its blown. if you dont have any blown airbag, don't foget to take the battery off aswell and do the install so you wont have any SRS LIGHT problem like me.
Old Jan 13, 2007
italy273's Avatar
italy273 is an unknown quantity at this point
I belive he means for the rears. I just finished modifying mine and I just have to install them.
I took pictures and plan to make a DIY soon.
Old Jan 13, 2007
since you brought it up, it can be rear but he didnt say rear so no one knows if its rear or front. but as for rear, you definitely have to do alot of modding. ALOT!
Old Jan 13, 2007
Michalo187's Avatar
Abortion Survivor
^^^^ What needs to be done for the rears
Old Jan 13, 2007
TemjinX2's Avatar
you need take the leather off the top rears. take out the sheet pans. cut off the sheet metal. cut off the side locking mechanism connected to the sheet pan of the top rear seats. Then put the pans back into the foam and put the leather back on. you need to cut part of the foam off in order to fit flush into the rear of the back seats. just dont cut off too much unless you want your rear seats too look out of place.
The biggest pain is drilling out the spot welds. if you were a noobie like me at it, it'll take you hours.
Old Jan 13, 2007
[QUOTE=TemjinX2;4128680]you need take the leather off the top rears. take out the sheet pans. cut off the sheet metal. cut off the side locking mechanism connected to the sheet pan of the top rear seats. Then put the pans back into the foam and put the leather back on. you need to cut part of the foam off in order to fit flush into the rear of the back seats. just dont cut off too much unless you want your rear seats too look out of place.
yep, thats pretty much it, nothing biggy. oh btw, I got my RSX REAR from Temjin (Mike) hehe
Old Jan 13, 2007
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
I have the 02 rsx and the were not a direct bolt on some minor custom work had to be done
Old Jan 13, 2007
ESK1k20A2's Avatar
unless the 05 seats r a direct bolt on
Old Jan 13, 2007
Michalo187's Avatar
Abortion Survivor
wow sounds like to much hell for me. I will probably just get the fronts
Old Jan 13, 2007
nope it isnt at all. minor mod like filing the wholes front RSX brackets (4 in total) you can make 3 fit but the last one tends to be off and thats the last one where you need to file. (i filed mine one of the rear ) and dont forget to put washer on the inner rear so the seats wont tilt inwards. (and for some reason, the driver side bolts on perfectly... well kinda.)
RSX seats 05 = sex!!
Old Jan 13, 2007
and yea, let me know how the SRS treats ya. remeber, take the battery off before uninstalling the stock ( i forgot to do on mine for being TOO excited)!
Old Jan 13, 2007
Michalo187's Avatar
Abortion Survivor
Any one wanna drive to Arizona to help me do all this **** hahahaha.
Old Jan 13, 2007
TemjinX2's Avatar
you can do it, its not difficult. its just labor intensive. it took me 6hrs because i didnt know what the hell i was doing and it was the first time i ever used a angle grinder. A pro can probably do it for you in an hr.
Old Jan 14, 2007
yep I was taking about the fronts (sorry didnt specify) have the backs as well however thats gonna have to wait for when I, gonna have some time off.. thanks for the help guys will post pics once up
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
carid
Sep 28, 2015 10:13 AM
PunX
Sep 23, 2015 10:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
