Blacking Out/Clearing headlights hellppp
Lol, i know theres like 50 billion threads about this topic but since the server has changed i cant access any pictures of how to do this, i know its easy to remove the bumper but could i get sum pics of how to remove the actual lights and things, thanks a lot.....also, im adding a type r mesh grill to my setup, i was thinking i take out the old grill line up the new one so its flush, and then drill the holes accordingly so it sits proper, but how do i fasten the screws should i use a nut?? or are the holes on the grill identicle to the ones of the oem grill?
New Mod on the Block
dude... you can see the bolts you have to take out to remove the headlights as soon as you take off the bumper. its common sense. if you cant figure that out, you have no business attempting to modify your car in any way.
it is pretty obvious. Theres like two on the top, and one or two hiding behind the bumper I think. If you can get your bumper off with out trouble, you can get your headlights off in about half the time. Just untwist the sockets to remove them from the headlight housing. Get all the screws, and then pull it out. I swapped my lights to TYC a few months ago wtih out any problem and no direction, its easy man. As for the grille... If it was designed well, it should just fit with the oem holes and hardware. I wouldnt use screws. I'd use some plastic clips from Honda, and if I that didnt work, I'd use a nut and bolt. Screws could stip the plastic and cause a bunch or problems that you shouldnt need to run into. Hope that helps.
From: i stay in oak lawn il. but im allways in chinatown chicago.
Re: Blacking Out/Clearing headlights hellppp
there's 2 or 3 bolts on the top and 2 bolts on the bottom of the headlight when u take of the bumper. its simple as pie.
MamaBear2015
49
Sep 29, 2015 01:12 PM
MamaBear2015
Sep 4, 2015 09:04 PM
jpat21
Sep 3, 2015 11:32 PM
mac25
Aug 21, 2015 11:14 PM
