blinker problem
Old Dec 7, 2006
Cocky's Avatar
Cocky guys kick ass!
blinker problem
For some reason my left blinker (front and back) have decided to not work while the headlights are on. I changed a fuse because the fuse for the tail lights blew, and since then the left side blinkers won't work when the headlights are on.. but they work fine when they're off. The right side is perfectly fine.. any ideas?
Old Dec 7, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Is there a fuse for the blinkers? If so did you check that? Maybe it blew when you changed the one out for the taillights.
Old Dec 7, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Add more blinker fluid.
On the serious side of things Check the harness for a broken/melted wire or a short, and check the combo switch on the column for the same thing.
Old Dec 8, 2006
CraigW's Avatar
Someone posted a similar problem recently, It had something to do with the ground lead from the headlight switch left un-hooked after recent work done.
Old Dec 8, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
why did the fuse blow in the first place?
MyCivic
Electrical
Oct 28, 2021 11:06 PM
jtdunn4life
Oct 27, 2015 03:33 AM
form3hide
Jan 19, 2002 06:36 PM
SneakerPimp
Jan 8, 2002 05:27 PM
Hondasport01
Dec 17, 2001 01:53 PM
