Neuspeed 1.75 Drop Problems
Old Mar 13, 2002
KOPSEAL's Avatar
KOPSEAL is an unknown quantity at this point
Hey guys. Its been about a month or 2 since I put on my neuspeed race springs and I noticed when I got them the usual settling noise that we commonly hear
when new springs are put on the car. Well after 2 weeks this noise did not go away and to this day about 1 and a half months later Im still hearing this noise.
It sounds like a popping and crunching when I turn the steering wheel during slower driving and when I hit road bumps and what not it starts to knock. I don't know
what is causing this problem so any help would be appreciated. Thanks
Old Mar 13, 2002
burtn6's Avatar
burtn6 is an unknown quantity at this point
it might be your struts? Where is the noise comming from? when my friends 94 accord was lowered he hear those noises to and ignored them thinking that they were just breaking in. But we went to the place and checked them out and found out the his rear struts were blown. Take it in and have them look at it cuz they shouldnt be "settleing" still.
Old Mar 13, 2002
1973's Avatar
1973 is an unknown quantity at this point
if you have the race springs, you have a 2.25f/2.0r drop.....that noise can continue for quite some time, i have sprint susp. 2.0 drop, and it took at least two months for them to settle properly and stop making that noise, i wouldn't worry too much about it right now......has it gotten less frequent, or quieter????
Old Mar 14, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
a 2 in drop? When I put my coilovers in my car, I found out that my tie-rods catch on the frame only when I turn. That popping sound is probably the frame when your tie-rods bolts catch it. Jack the car up by the front lower control arm and remove the wheel. You should be able to see whatz up(dont forget the lock the wheels with some wood).
Old Mar 14, 2002
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Did you remember to put the big plastic washer thing that goes between the upper spring perch and the top of the strut on the front? I just did that when i took my coilovers out to put in my stock springs. Got like 20 feet out of the garage and realized that they were making WAY too much noise....
Old Mar 27, 2002
NucRacer's Avatar
NucRacer is an unknown quantity at this point
Could be that the springs are place in the shock the wrong way.
I have the same problem too and I asked a Neuspeed Rep. and this is what he said:
[i]Test[i]
As you have already found out, the writing does not necessarily indicate
proper orientation of the springs. In the case of your front springs,
it sounds to me that either the springs are not oriented the correct
way, or the strut bearing was not installed correctly. The strut
bearing allows the strut and spring to turn as one unit. If it is
installed incorrectly, the spring will turn independently of the strut
causing noise.
Text
So hopefully this will help.
Old Mar 27, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
<< Did you remember to put the big plastic washer thing that goes between the upper spring perch and the top of the strut on the front? >>
I forgot that the first time too, horrible sound. I can change my springs in under 2 hours now![IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 2, 2002
Outkast27's Avatar
Outkast27 is an unknown quantity at this point
Get some speaker wire loom (Black plastic stuff you put wires in to keep them neat) and put 3" pieces of it around all of the bottom part of the spring (the part of the spring that stacks, first 3 or 4 coils from the bottom). This will keep the coils from rubbing when you turn, aleiviating the noise.
Rogelio Rey
May 24, 2015 08:30 PM
aZnVoYCe
Dec 23, 2001 12:39 PM
burtn6
Dec 17, 2001 10:13 PM
EuroCivic
Dec 7, 2001 12:56 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
