HELP PLEASE: NO MORE SOUND
Old Mar 12, 2002
SubstanceX's Avatar
SubstanceX is an unknown quantity at this point
okay here's the problem.
When your head lights are on and you take out the key
there is suppose to be a sound coming from somewhere to indicate
that your head lights are on right?
well ever since I got my deck installed by a local electronics store,
that sound does not go off anymore.
After the deck was installed there was a problem with the security led
so I returned to them and they said that they hooked the wire for the light
onto some ignition wire so when my car turns off the light turns off too.
I don't want to bring the car back to them because I don't want them to
screw around anymore.
Anyone know how I would get the sound back?
Old Mar 12, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Try putting your stock deck back in and see if everything goes back to normal. If it does, tell the jerks who put your hu in to refund the installation money because they screwed it up...
Old Mar 12, 2002
Voiceofid's Avatar
End Bringer
mine doens't sound anything when i have my headlights on and the key pulled, it would sound when i open the door
Old Mar 12, 2002
DJNuTzSaK's Avatar
DJNuTzSaK is an unknown quantity at this point
i don't there is a sound when your headlights are still on but when you have your key still in the ignition it makes the beeping noise
Old Mar 12, 2002
SubstanceX's Avatar
<< mine doens't sound anything when i have my headlights on and the key pulled, it would sound when i open the door >>
wow you guys answer pretty fast
well anyways yeah it's suppose to have a sound when you open the door with the key out and the light is on, but mine does not have the sound anymore.
I'll try putting the stock unit back in to see if it fixes the problem, but I won't get a refund for installation because it was free.
thanks guys
Old Mar 12, 2002
Voiceofid's Avatar
End Bringer
i personally don't think it's a problem, because it will still sound when i open the door
Old Mar 12, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Technically, it was not free, it was included. And obviously, the installation staff hooked up something incorrectly. If installing the stock deck fixes the problem, then you are lucky. If not, then you are in for some problems.
I have a few questions, what is the reference about the LED for the security?
What store did the job, and do you know that they used an adapter harness?
What other modifications are on your car as far as electrical?
Are any other things not working, like dash lights, dimmer on the dash lights, running lights. Does the beeper go off at all if you start the car with the door open? There are a number of wires on our cars that are multiplexed, meaning you cannot simply hook up to any wire anymore. I can look it up more at home, but I still need some more info.
Thanks
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
