CEhck Engine Help
Old Jun 27, 2006
TitoTheNightKid's Avatar
TitoTheNightKid is an unknown quantity at this point
CEhck Engine Help
after i installed my track pipe and my cold air i have a check engine light do i have to take it to honda to have them reset the sensors
Old Jun 27, 2006
Civicman1988's Avatar
no take it to auto zone and have them scan it. Just tell them you ahve a check engine light on. They dont charge aanythign here in michigan should be the same all over
Old Jun 27, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Read Your Owners Manual. It Tells You How To Reset It
Old Jun 27, 2006
Nakattk's Avatar
Nakattk is an unknown quantity at this point
All you should have to do to reset the sensors is disconnet the battery cable for one min. If it is still on make sure you put the sensors in good. If this doesn't work make sure you didn't break one of the sensors.
Old Jun 27, 2006
bullet02ex's Avatar
bullet02ex will become famous soon enoughbullet02ex will become famous soon enough
it will go off within 10 days..... computer has to reset becauser of the track pipe. I believe summit now sells some product that will turn the check engine light off when the track/test pipe is installed. pm me if u need more help.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
